man every time I pop into this thread - makes me want one soo bad after seeing the black one.
Agreed.I think I'm just gonna back anything this guy makes at this point. Really amazing job, super excited to get the final product. I don't even care that it'll be empty for a few months still, I'm sticking it on my desk.
Check Phanteks Glacier (flat res). With 280 at the bottom only PH-R160 fits, but with only 140 rad you even should be good with PH-R220.Ideas on which reservoir / pump combo?
I have a 3080FE with the super short EKWB FE special edition waterblock (206mm) on the way. One of the things that drives me crazy with ITX watercooling is not having a decent sized reservoir. I know I could use an external res to do it, but a lot of times finding a decent space for quick disconnects is tough. This time around the plan was to only use a single 140mm radiator in the bottom and have a decent sized tube res with pump next to the gpu.
But I'm having a hell of a time finding one that seems like it would fit.
Doesn't look like I can do an EKWB flat res next to the gpu ( 312 -207 = 105)
I like the looks of the optimuspc res (that're sold out except the 5.75) but the tube is 70mm thick and I don't think there's that much space between the spine and sidepanel?
Other ideas that I'm missing?
If my guestimation is correct, then the discontinued EK XRES 100 (unsure what the modern equivalent is) will fit between top&bottom fans/rads. Currently planning on using that and going with a 206mm FE EK block as well. The fittings to make it work will get a bit weird.I use one of these on my work bench, attached to a D5 pump for flushing/filling when necessary. It has a 50mm diameter and it's cheap. Be warned though, it also looks/feels cheap.
If you can get one that fits the height requirements, and you have a pump top with inlet on the top, it should fit.
Agreed.
I've bought stuff from many of the premium brands. Like op, I'm constantly disappointed in products.
So far, quality wise, Optimus has been the only pc company not to disappoint me. I'm looking forward to adding winter one to the list.
Is there a release date for the black case?
Darn I'm running out of stuff to buy to hold me over.I worry that we may need to push this back *again*.
Darn I'm running out of stuff to buy to hold me over.![]()
As I mentioned on the Discord the other day, the only reason I'm now waiting for Optimus blocks is that it fits the theme you've set here with the case design.I never once thought Winter Design Co would be compared to Optimus. I absolutely adore their waterblocks, and they're truly a company to strive towards. I feel flattered, and not worthy of it. But I'll do my best to make it so. Thank you for putting that kind of trust in me, and in this project.![]()
System | |
Motherboard | Asus Strix x570i (newest bios) |
CPU | Ryzen 9 3900x (Asus default OC settings) |
Memory | G.Skill F4-3200C14D-16GTZR (OC 3400) |
Cooling Hardware | |
Radiator | HWL LX 360 |
3x Fans | NF-F12 |
Pressure Gauge | Wika 15 psi |
Flow Meter | Variable Area, 6 psi DP @ 40 gph |
2x QDCs | Alphacool Eiszapfen |
Temp Sensor | Barrow 10K Stop Fitting (not calibrated) |
Control Variables / Setpoints | |
Fan Speed | 50%, 776-795 rpm |
Flow Rates | 8 gph (.505 LPM) @ .6 psi DP |
16 gph (1.010 LPM) @ 1.4 psi DP | |
24 gph (1.514 LPM) @ 2.8 psi DP | |
Ambient Temp | 70F |
Humidity | 36-38% |
Pump RPM | Pump % | CPU Temp (C) | |
8 GPH | |||
Aquanaut - DDC 3.2 | 1635 | 23 | 81 |
Apogee II - DDC 3.2 | 1460 | 22 | 75.4 |
Velocity - D5 | 1650 | 37 | 71 |
16 GPH | |||
Aquanaut - DDC 3.2 | 2710 | 34 | 75 |
Apogee II - DDC 3.2 | 2370 | 31 | 70.1 |
Velocity - D5 | 2790 | 58 | 68.4 |
24 GPH | |||
Aquanaut - DDC 3.2 | 4020 | 47 | 73 |
Apogee II - DDC 3.2 | 3400 | 41 | 69 |
Velocity - D5 | 3850 | 78 | 67.1 |
Great work. This confirms my observations regarding the relative performance of Aquanaut and EK Velocity.Here are some results from a pump block vs. standard block test. This test helped me decide what to do in the W1 so maybe it will help others.
The information below combines two different systems of measurement and weird table formatting. Read at your own risk.
System Motherboard Asus Strix x570i (newest bios) CPU Ryzen 9 3900x (Asus default OC settings) Memory G.Skill F4-3200C14D-16GTZR (OC 3400)
Cooling Hardware Radiator HWL LX 360 3x Fans NF-F12 Pressure Gauge Wika 15 psi Flow Meter Variable Area, 6 psi DP @ 40 gph 2x QDCs Alphacool Eiszapfen Temp Sensor Barrow 10K Stop Fitting (not calibrated)
Control Variables / Setpoints Fan Speed 50%, 776-795 rpm Flow Rates 8 gph (.505 LPM) @ .6 psi DP 16 gph (1.010 LPM) @ 1.4 psi DP 24 gph (1.514 LPM) @ 2.8 psi DP Ambient Temp 70F Humidity 36-38%
Setup and comparison of designs:
Results:
Notes:
- 50% fan speed & controlled HVAC resulted in approx 29C coolant temp (uncalibrated) for each test.
- Test configuration created a larger pressure drop than what you'll see with a dual HWL 280GTS setup. Real pump speeds will be lower than shown.
Pump RPM Pump % CPU Temp (C) 8 GPH Aquanaut - DDC 3.2 1635 23 81Apogee II - DDC 3.2 1460 22 75.4Velocity - D5 1650 37 7116 GPH Aquanaut - DDC 3.2 2710 34 75Apogee II - DDC 3.2 2370 31 70.1Velocity - D5 2790 58 68.424 GPH Aquanaut - DDC 3.2 4020 47 73Apogee II - DDC 3.2 3400 41 69Velocity - D5 3850 78 67.1
I wanted to also quantify noise, but that turned out to be too much of a challenge. Needless to say the D5 is insanely more quiet than the DDCs on the Aqua and Apogee. The Apogee had significantly more vibration and motor noise than the Aquanaut, but could be due to years of abuse or slight differences between the DDCs. In hindsight I should've swapped the Aqua DDC over to the Apogee before testing.
After managing to snag a 6800 XT ref. ed for MSRP on release day (I've been feeling more and more like a lottery winner ever since considering the non-ref. cards are all sold out AND atleast 50% over MSRP in Denmark) and then 2x HWL 280 GTS rads and a Corsair SF750 PSU last week, it looks like I will be building my first custom loop in the Winter One despite the misgivings of my wallet.
However I am a bit uncertain about choice of pump/res. After some reading it appears a D5 would be the best choice but I am not sure I will be able to fit one. The shortest 6800 XT ref. block I've found is the Alphacool Aurora at 262,5mm length and 130mm height. This leaves only 52,5mm for pump/res between the front of the case and the GPU, and I don't see any way to fit a D5 in there.
So second choice then is a DDC, but the whole point of this is to make a silent build and I have not read the best things about CPU blocks with integrated pumps (such as the new-ish Barrow and the old Apogee II, both of which can be hard to get a hold of anyway). Most of the discussion I have seen on here is about using the extremely short PCB of FE 3080/3090 to fit in a D5, so I haven't found a good solution so far. Has anyone with a longer GPU made plans around a stand-alone pump and possibly even reservoir?
You can put it in several places in whichever orientation works for you - you just screw two screws of the quadro to the spine holes.Just a quick question, where is the quadro installed in the W1? I'll do like @biopunk (see here) and replace the USB cable. I would like to order the right length of cable. (PicoBlade female pre-crimped leads) Thanks
You can still use a DDC or MCP50X without having to use an integrated CPU/pump block. Just be sure to turn it down to around 20-50% power and you’ll be fine.After managing to snag a 6800 XT ref. ed for MSRP on release day (I've been feeling more and more like a lottery winner ever since considering the non-ref. cards are all sold out AND atleast 50% over MSRP in Denmark) and then 2x HWL 280 GTS rads and a Corsair SF750 PSU last week, it looks like I will be building my first custom loop in the Winter One despite the misgivings of my wallet.
