The Slots in the central spine are spaced such that the quadro can be mounted on any 2 adjacent slots. It's mounted on the same side of the spine as the Motherboard, and is somewhat tucked away behind the power supply.Just a quick question, where is the quadro installed in the W1? I'll do like @biopunk (see here) and replace the USB cable. I would like to order the right length of cable. (PicoBlade female pre-crimped leads) Thanks
The way you build in Winter One, is you route all cables onto the central spine, and get the terminating ends in position near the power supply, plug them in, and then turn the power supply upward and mount it to the bracket. Placing the power supply and wiring it in are the *last* steps before you complete your build. Leaving it out allows you to manage the cabling really easily. Here, I have a lower and upper cable velcro strip. I could lower the spacing of that strap by 1 and mount the quadro along the top 2 points, or mount it over the fan hub of the GPU exhaust fan.
