Will my system have enough power?
kz1343
Will a HD-Plex 300w run these components?
CPU: Intel i5-7600k
CPU Cooler: Zalman CNPS2X
Motherboard: MSI B250I GAMING PRO
RAM: Kingston HyperX Fury Black 8GB (2x4GB) DDR4
Storage: Samsung 850 EVO 250GB M.2-2280
Hitachi Travelstar 1TB 2.5" 7200RPM
GPU: Geforce GTX 1070 8GB Mini
Fan: Scythe SY1212SL12H
(Case: S4 Mini)
I checked the needed power for the system and it said it was ~310w but I also heard that the HD-Plex can provide much nore power than 300W. So will my system run? (I don't want to buy the parts just for them to not work.)
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
If you are using PC Parts Picker estimated wattage draw I find that it is pretty generous, which is a good thing at the end of the day.
However the 7700K version of that system draws 220w during Futuremark on my bench (minus the HDD) so I think you are going to be fine. The HDPLEX 300 powers that system quite well, but what you need to make sure is your power brick is beefy enough.
Peace.
kz1343
Peace.
