Selling Power Sale: Everything must go!
Car show season is coming soon and I have project car that needs some love.
Time for a power sale!
- Buy 2 items and get 20% off total price (excluding shipping)
- Buy 3 or more items and get 25% off total price (excluding shipping)
- FREE case badge of your choice with each purchase (see the very bottom).
- Shipping within the US only.
- Shipping costs not included.
- Payments can be made via PayPal.
- Will ship out same week payment is received.
Unsold:
6+12 pin 256GB SSD from 2010-2011 Macbook Air - $40
120GB Kingston HyperX 3K SSD - $20
(2x4GB) 1.35v 30nm Samsung DDR3 low-profile memory capable of 2400MHz -$40
(2x4GB) Micron D9 DDR3 laptop memory - $20
(2x4GB) G.Skill TridentX DDR3 memory 2400MHz. - $40
Sapphire Radeon AMD 6950/6970 - $20
EVGA NVIDIA GTX690 Hydro Copper by Swiftech 4GB (Dual GTX680 GPUs) - $100
Liquid Cooling Tubing cutter - $5
Ice Dragon coolant w/ Zinc nanoparticles (White) - $5ea
Alphacool NexXxos 280mm UT60 (2x140mm, 60mm) - $30
Aquacomputer Airplex Modularity 280mm radiator w/ adjustable D5 pump + Reservoir + Lasercut grill - $80
Cryorig M9A HSF - $10
Lamptron FC5 Rheostat PWM Fan controller - $20
Corsair H80i 120mm - $20
Never used original Microsoft Intellimouse - $10
2x The Original IceMat mousepad, before they became Steelseries - $10ea
2x Steelseries 7G Mechanical non-backlit, non-RGB, PS/2 keyboard - $20 for the one without USB, $25 for the one with USB)
Overlord Tempest X270OC 27" 2560x1440 120Hz 8-bit IPS display - $120
ERGOTECH Freedom Monitor Arm - $40
QNAP TS-459-PRO+ NAS (4x3.5" HDD, Dual-Core Intel Atom powered NAS - $400
Lian-Li Solid Aluminum case feet - $20
AMD Kaveri A10-7850 APU + MSI GTX 760 Mini build - $300
Ammo Can to rival a DanCase A4 or Louqe Ghost S1 - $20
Sold:
EK Supreme HF Waterblock for socket 1150 processors
2x Noctua NF-F12 2000RPM 120mm PWM fans
Koolance 380i CPU block for socket 1150 processors
Alphacool NexXxos 240mm XT45 (2x120mm, 45mm)
All kinds of Bitspower Fittings
250GB Samsung 960 EVO
500GB Samsung 960 EVO
4.8GHz capable Intel i7-4770k
AMD Wraith Prism HSF (RGB galore, came with the 2700X)
Unopened 30CM PCI Riser Card (Flexible)
EVGA 80 Plus Gold 500w 1U PSU from an EVGA Hadron
Cougar 700m Metal Frame adjustable mouse w/ Sniper Button
Lutro0 Customs Ratchet Crimper for making custom length PSU cables
Fractal Define Mini-C
EVGA Supernova 850 G3, 80 Plus Gold 850W, Fully Modular
Aquacomputer airplex modularity system 240mm
Aquacomputer Aquatube Delrin Reservoir
Anker 10-port 60w USB 3.0 Hub
500GB Samsung 960 EVO - SOLD
250GB Samsung 960 EVO - SOLD
6+12 pin 256GB SSD from 2010-2011 Macbook Air (can be converted to SATA or External SSD) - $40
- 5.4cm with removable heatspreader, 3.9cm without
This is a 1st gen reference card where the number of shaders were actually controlled by a little switch.
On one side of the switch is the 6950 (1,408 shaders), and without costing a penny more, the other side is a 6970 (1,536 shaders)
This is the very last dual-GPU card that NVIDIA produced and it's just as fast as a single GTX 980 in today's games.
- Capable of outputting to 4 displays
- 1440p @ 120Hz capable.
- Includes 4 unused EVGA Compression fittings.
The top sticker was removed because it was put on crooked from the factory.
4.8GHz capable Intel i7-4770k (Delidded) - Ran at 4.7GHz stable. - SOLD
EVGA Supernova 850 G3, 80 Plus Gold 850W, Fully Modular - SOLD
EVGA 80 Plus Gold 500w 1U PSU from an EVGA Hadron - SOLD
Unopened 30CM PCI Riser Card (Flexible) - SOLD
Lutro0 Customs Ratchet Crimper for making custom length PSU cables - SOLD
EK Supreme HF Waterblock for socket 1150 processors - SOLD
Koolance 380i CPU block for socket 1150 processors- SOLD
- Great for pastel colors.
- Requires regular cleaning.
- No silver killcoil or PT Nuke needed.
Alphacool NexXxos 240mm XT45 (2x120mm, 45mm) - SOLD
- Requires modding a case to install
- Does not include 2x 140mm fans.
Aquacomputer airplex modularity system 240mm - SOLD
Aquacomputer Aquatube Delrin Reservoir - SOLD
All kinds of Bitspower Fittings - SOLD
- 124.6mm
AMD Wraith Prism HSF (RGB galore, came with the 2700X) - SOLD
2x Noctua NF-F12 2000RPM 120mm PWM fan. - SOLD
Cougar 700m Metal Frame adjustable mouse w/ Sniper Button - SOLD
- Choose white or black, or both.
- Non-RGB
- Made from 100% Frosted Glass
- Cherry MX Black linear switches
- Thin bezel w/ internal metal frame.
- Hulk proof.
- Garage kept, lightly used.
- Needs cleaning.
- Pixel Perfect model
- Not for lightweight panels.
- Perfect for the Overlord panel above.
- Supports up to 34" panels
- Raid 0,1,5,6,10 capable.
- Includes 4x2TB Seagate 3.5" HDD
- Load Balanced ethernet.
- Runs Plex or Kodi like a boss.
- Quickcopy USB function on the front. Dual ext. SATA at the back.
- Supports the use of a Kensington lock
- Requires modding
- 210mm wide from end of wheels
- 140mm mounting base.
- Built-in locking mechanism
My performance numbers: https://hwbot.org/search/submissions/permalink?username=3lfk1ng&cpuId=3148
- 15.14 liters
- AMD A10-7850 Kaveri APU
- Gigabyte GA-F2A88XN-WIFI mobo
- MSI GeForce GTX 760 Mini 2GB
- 30nm 1.35 Samsung memory
- Cooler Master Elite 110 case
- Corsair SF450
- 120GB SSD
- 1TB Mechanical
Fractal Define C Nano - SOLD
- Requires modding
- Internal Dimensions: (D) 280mm x (W) 135mm x (H) 178mm
- 6.72 liters
Thank you for looking!
3lfk1ng
906
1,709
www.reihengaming.com
500GB Samsung 960 EVO - Reserved
4.8GHz capable Intel i7-4770k (Delidded) - Reserved
2x Noctua NF-F12 2000RPM 120mm PWM fan - Reserved
EK Supreme HF Waterblock for socket 1150 processors - Reserved
6x Compression fittings fittings - Reserved
3lfk1ng
906
1,709
If the reserved items are not paid for by tomorrow at midnight, the reservation will expire and become up for grabs again.
The 4770k has a backlog of 6 people interested in it, if this occurs, the offer will instead trickle down from one to the next.
If you're one of the 6 that have expressed interest in it, I know who you are!
Buyer number 2 will likely submit payment today so I don't expect the 4770k to trickle down any further at this time (just wanted to keep eveyone in the loop).
If you have already submitted payment, your package is going out today around 1:00pm PST.
The list of the items up for grabs has been updated.
Thank you again for looking.
3lfk1ng
906
1,709
Reservations for the YELLOW items above will expire tonight at 120:00PM if I do not receive payment from the interested party.
At that point, those products will become up for grabs again.
All PMs responded to.
The original post has been updated.
buttrmytoast
52
27
Interested in the Aquacomputer Airplex Modularity 280mm radiator w/ adjustable D5 pump + Reservoir + Lasercut grill if available at this point
