I see your concern about heat from the CPU cooler.
Suggest you check the orientation of your CPU cooler.
If possible, install the cooler with its fins pointing to that long strip of vents so that roughly half of the exhaust will go in that direction and escapes the case. This is better than having the fins running parallel to the strip of vents.
See the 2 pics below for illustration. Pic #1 is not ideal while pic 2 shows a better orientation.
Got it, thanks a lot for the help
I'm not entirely sure if this has been mentioned before, but there's pre-orders on two new Mac Pro inspired cases. One is a M1 layout with 240mm aio support with the included bracket, The other is in Cerberus layout with M-ATX motherboard support.
淘宝网 - 淘!我喜欢
淘宝网(Taobao.com)作为专业的购物网站拥有全球时尚前沿的消费者购物集市,100%认证网上商城及超值二手商品区,同时购物安全,产品丰富,应有尽有,任你选购,让你尽享网上在线购物乐趣!
item.taobao.com
淘宝网 - 淘!我喜欢
item.taobao.com
