Other What's on Taobao
dreadpiratebob
ZS-A4S V3
While the DC V2 looks like a step backward (now Flex; wasn't V1 a DC-DC variant?), the ZS-A4S V3 looks tasty as hell. :) Esp. now it looks like 92mm fans are a go, rather than the hard to source 80mm. I can't work out from the listing when they're expecting to ship, though. Seriously tempted to give it a go, despite the current international shipping constraints.
Tuscany
159
63
Can someone help me with a link to zs-a4s? I found someone who can buy it for me, but I don't seem to be able to find it - it does not let me search if not registered ...
pseudobacon
59
97
Currently on preorder. 30th May will have stock
smitty2k1
978
501
I look forward to seeing the V2 versions of the ZS-A4M and ZS-A4DC. When they put out a V2 version of the ZS-A4S but not the other two, I figured they were discontinued.
MrClippy
126
143
More taobao lurking
JL Make One
Basically a acrylic/beam version of the Salvo S401
CPU cooler height is 47mm, GPU length is 310mm, total volume 8.25L
Travel Cat DIY
Sorta bigger version of Salvo S401, but made of acrylic panels and beams
Can support MATX or ITX with a 240 Rad cooler. CPU cooler height is a tall 100mm, GPU length is 330mm. Total volume is 15.02L
Portable control chassis
Now this is a beauty. You're basically gonna have a laptop here without the battery but with the upgradeability of an ITX PC.
Total volume is 10.26L for the 15.6 Inch version, and requires using a 1U or flext ATX power supply. Uncertain on the CPU cooler height but probably below 47mm. Uncertain on the GPU length as well, but it mentions half length PCIe so possibly ITX or 175mm. Allegedly there's a touch screen option available as well.
Another model?
Bigger version
Same as above but for audio personel is my guess.
Triple screen version
Little information on this, but it might be a mobile CPU soldered version.
Tower ATX form
Reactions: Jerdz
MrClippy
126
143
Dual screen version
possibly touch screen for bottom screen?
SomeBoredGuy
Loving the look of the look of https://www.superbuy.com/en/page/buy?url=https://item.taobao.com/item.htm?spm=a1z10.1-c.w4004-21931576252.2.1b7b4c27jAXzSC&id=600299686532&nTag=Agent-product-search&from=search-input
just had some questions.
Where would be best to grab the supported ADT riser since it doesnt have the option ?
it mentions that it has black/silver does it mean it has the internal red accents plus this or is just black ?
guessing that my best bet of cooler would be the thermalright axp 100 ? does this cooler have any known issues with motherboard clearance like the black ridge ?
also considering
whats the difference between the packages ?
sorry to be a pain long time lurker :)
did get a jonsbo a4 itx from ple computers but got the fever for a smaller case now :) (also i hate the tempered glass but im getting custom panels)
edit found the riser
as for the package differences looks like its the different models A being for the smaller one and Two being for the 240 aio one
tinyitx
2,279
2,338
also considering
Read post #1383 of this thread by member BeerNsoup. He said he has ordered recently from the Acat seller who speaks English. So, suggest you ask BeerNsoup about how to contact the seller directly. Also, might ask him about ordering through Superbuy.
rocklobster
93
23
Awesome link, thank you!
I am looking for this one - The one with the smallest footprint (like Lilo1 V2).
Oh damn that's my build! I gutted and shifted this build to use as a HTPC. Tricky to build because of the PCIE and motherboard tension. I would look at the K39, K49 or the Metalfish S3, I think those are better made because they are made and sold in much higher volumes than the ZS-A4M, though the V2 does look pretty good. The other cases I listed also allow slightly longer GPUs which opens up a lot more choices like the 1660. Also the thin fans at the top of the case don't do much beside make a load of noise.
The S3 Metalfish Plus looks good too, regular PSU support plus longer GPUs is always welcome.
Gilles3000
242
248
The Vikingdom M1S has exceeded my expectations. I'd say it has better build quality than the DA2.
Glad to finally see someone that bought one. Do you have any pictures or perhaps even a build log?
And if you don't mind me asking, how much did you end up paying in shipping, agent fees and taxes? Have been interested in this case for a while but I'm a bit wary of how expensive it could end up being.
Reactions: thelaughingman
pseudobacon
59
97
Seems like AKLLA have updated the details on their imaginatively named A4-atx. But still no overall dimensions
Overall dimensions: ?
CPU heatsink height: 76mm
GPU support: 330mm
I didn't see the A4s mentioned either so here it is. More details available on this one.
Overall dimensions: 33.5x15.5x20cm = 10.36L
CPU heatsink height: 68mm
GPU support: 330mm, 58mm width
2.5" hard drives: 2x
New case called the A387 showed up
Overall dimensions: 21.5x18x10cm = 3.87L
CPU heatsink height: 40mm
GPU support: 175mm
WANDU also appear to be new with two cases:
M1
Vertical format with mATX motherboard support (24.5x24.5cm)
Overall dimensions: 25.5x15x32.5cm = 12.4L
CPU heatsink height: 131mm
GPU support: 250mm, 130mm height
2.5" hard drives: 4x at most
3.5" hard drives: 1x (will be interfered with SFX-L sized PSU)
Fans: 2x 9025 top, 1x 9025 rear, 1x 9025 bottom
PSU: SFX/SFX-L
L1
Vertical format again with SFX PSU and no video card support. Very odd indeed. Base is detachable. Also odd is the power button, which is at the bottom of the front.
Overall dimensions: 18.5x7.5x31cm = 4.3L
CPU heatsink height: 55mm
2.5" hard drives: 2x at most
PSU: SFX
New seller called ZIKIM has showed up. But very new and no feedback yet. The designs look pretty cool though
