https://world.taobao.com/item/587600183373.htm?spm=a21wu.12321156-tw.0.0.47b83200fzhoaO
https://world.taobao.com/item/589239911288.htm?spm=a21wu.12321156-tw.0.0.3e57d8faugwqiv
https://item.taobao.com/item.htm?sp...21269506603.22.6c5323c35WlZwB&id=587071012014
https://item.taobao.com/item.htm?sp...21269506603.12.6c5323c35WlZwB&id=574033491663
https://world.taobao.com/item/577068558061.htm?spm=a21wu.12321156-tw.0.0.1d4c6236L6z6cZ
https://world.taobao.com/item/567897537938.htm?spm=a21wu.12321156-tw.0.0.1d4c6236L6z6cZ
https://world.taobao.com/item/587089152305.htm?spm=a21wu.12321156-tw.0.0.679b5134zFxBGK
I build a ZS-A4M which is the same model less the HDPlex but with a flex PSU. Case has nice thick panels but these sandwich cases are pretty flimsy by themselves. They get sturdier as you screw the components. Fitting a slimmer single fan GPUs (1060s, Gigabyte 1070 / 1080) is fine but I had a pretty bad experience with my MSI Aero 1070 ITX. Did not press the card in firmly while screwing the thumbscrews and the fan was getting caught in the holes in the side panel. Broke 1 fan and had to get a replacement.Has anyone had any experience with the zs-a4dc?
That color is ugly as sin but this was the exact form factor I was looking for a HTPC. A lot of cases have so much wasted space between the mobo and PSU or have zero ventilation slots (Streacom F7C).
Only LP GPUs isn't great but should be more than sufficient for a HTPC.
didn't realize that. Still very pricey though.you can request the color btw, mentioned on the seller pege
I liked the A4 Frisk but the CPU side has zero ventilation if you are going for air cooling. Air cooling = smaller GPUI really appreciate Warhead's creativity. The layouts are definitely unique and compact. The Super Reaper MKV Mini is especially bad-ass
https://item.taobao.com/item.htm?spm=2013.1.w4004-17203802128.10.67095809nYGEG4&id=569144805503
(cheap) wood itx laser cut case? Is it correct, 125 CNY with riser?
https://item.taobao.com/item.htm?sp...f952f24aXwY0I&id=587071012014&_u=t2dmg8j26111Hey anyone found slim case in taobao like zaber sentry or node 202 smaller? Thank you
