If you're running a card or two, I doubt they'd see the difference. As far as the rest of the system, you can get by with a cheap processor and only 4gb of RAM. Mining is a GPU intensive process for sure, but your CPU will hardly notice.
I thought Nice Hash uses CPU and GPU?If you're running a card or two, I doubt they'd see the difference. As far as the rest of the system, you can get by with a cheap processor and only 4gb of RAM. Mining is a GPU intensive process for sure, but your CPU will hardly notice.
What CPU do you think I should get? I'm thinking about one of the low ends LGA1151 Xeons?It will benchmark everything, but you can select what you want to mine with. In my case, I'm using GPU only. CPU's are horrible at mining. I mean, you might get $0.25 per day if you're lucky. Not worth it in any way.
Yeah, I was mining ZCash with a i3 just for the hell of it and getting about 35 cents in a week if the payout was constant. And considering 1 ZCash is worth around $350 now...
I'm contemplating what to do with my Z97 and Win7 system now that I've got my new laptop and have most of what I need to get up and running for work and home. It has Windows 10 and CPU chipset is two generations ahead of my home system. Might bite the bullet and sell the parts so I can continue with a Thin Mini ITX project. Still keeping the SSD, though.
Oooh, keyboards, tell me. What case color and switches did you order?Got better at my primary job, I think. I will check my stats tomorrow. I upgraded my phone to a Samsung Galaxy A5 2017 to enable me to do my secondary job better. I might exchange the phone after this weekend for a different colour. I have also ordered a Obins Anne Pro to help with my secondary job as well. I cannot wait for it to arrive. *CLACK-CLACK-CLACK-CLACK-CLACK*
Not going to apologize for my wallet first?Oooh, keyboards, tell me. What case color and switches did you order?
Nice, I like black, I'm not a fan of linears, I love clickies!!!Not going to apologize for my wallet first?I got the Anne Pro in black with Gateron Red switches.
I think you got your words messed up. I think you meant to say "Should have gone with blues."Should have gone with browns.
Blues are the king of switches, yes, though if I had a chance to fully customize my key switches, I'd go with greens instead on the home row keys.I think you got your words messed up. I think you meant to say "Should have gone with blues."
I hate linears also, but again, I think you messed up your words. It should be "Pandastotles are the king of switches, yes, though if I had a chance to fully customize my key switches, I'd go with Pandastotles instead on the home row keys."Blues are the king of switches, yes, though if I had a chance to fully customize my key switches, I'd go with greens instead on the home row keys.
That said, browns are a good middle ground, there's some feedback, but they aren't overly loud and the reset and activation points are the same.
Don't know how anyone can use linear keys.
Okay...Opinions are individual - you don't need to continue the 'correction' thing.
In that case, I hope you have some O-Rings on them.I mash the keys down when I type so the tactile actuation point on the blues or browns would just be getting in my way![]()
