Just registered here after seeing this project on discord. Very intrigued. I pretty much only do custom water cooled builds, so my perspective is from that POV. Perhaps you have set this up more for AIOs, and that's fine. But if you are desiging with custom loops in mind, I offer my 2 cents.
ATM I'm in an
O11D Evo (big case)... but am absolutely sick of the
O11 range of cases (<best build of mine IMO) and moving to SFF/SFF-ish next build. ATM my plan is the Johnsplus i100 Pro G (gutted and modded) + external Mo-Ra radiator, but getting enough cooling (>480mm total) in a single package is appealing.
First of all, I greatly appreciate the effort that you went through to bring me your two cents. I was not aware there was any discussion about this case on discord, could you link me to that? As a side note, your builds look incredible, and I appreciate you linking them
- I'd be interested in seeing the performance model w/3x240 rads. The standard and pro models with the 360 rad definitely looks chocked to the point of being impractical (at least if you are going >500w or so). That said, I totally get the "picture frame" aesthetic and for those configs, it's probably not worth compromising that too much.
I understand your concern with the 360 rad being choked, I am working on ways to integrate panels that can be removed to open up the middle of the case and bring fresh air from the front chamber into the rear. I assume that the gap between the motherboard and midplate will also be a good place for air to pass through.
- In the performance model, the left and right supports for the mobo tray look a little... out of place? The design ID seems different than the rest of the case. Nor are the holes large enough to facilitate meaningful airflow (it'll just go around, which may be fine). I would consider a more skeletal approach with the chamfered edges and soft corners seen on the other surfaces of the mobo wall. Maybe something Piet Mondrian-esk (your mobo supports are sorta in that direction).
I have been hesitant about that design choice as well. The holes are meant to balance the design rather than provide meaningful airflow. It is funny that you mentioned this because today's work has been about everything you mentioned here. I might even have a render up today to showcase what I mean. Additionally, so much has changed since the initial renders on the first page that I am going to be replacing those renders soon.
- Asking for D5 pump support is probably a no go, but in small cases, it's sometimes possible if you do a pump top (low profile like Aquacomputer's which is <100mm in any dimension) and the (flat) reservoir separately. Something to consider, as D5s are quieter.
- Reservoir compatibility and mounting is another important area. Not just fitting it, but also in a place that allows PIA filling and draining (one reason I've avoided SFF custom loops). IMO, the EK FLT 80 DDC (D5 if possible) would be good reservoirs to design around as they are widely available and compact.
- Fans and radiators often perform better in push than in pull.
I have a FLT 120 and FLT 80 in hand that I am designing the pump mount system for. I will ensure that they work.
- Spots for fan splitters or controllers (Aquacomputer Quadro/Octo). Doesn't have to be designed for them, just that those may be things people want to include in their setup.
There is a cutout in the rad/fan brackets that I intend to be a good spot for a fan splitter.
- I'd love to see polished aluminum (could sell as raw and have user polish. It's not hard) as an accent option. Or anodized black with machined edges (post anodization)
You're referring to the accent pieces that fit into the holes in the side panels?
- Interested on how cable management will work. It would be cool if you could publish recommended (custom) cable lengths. Perhaps screw holes for panel mount cable combs like those from Clockwerk Industries.
That's all I've got for now. I look forward to seeing how this project develops.
As for cable management, I have provided a lot of places to use cable ties/ Velcro straps. The idea is to route most of the cables in between the GPU and Rad up to where the motherboard is. Panel mount cable combs are definitely a thing I will consider
I really appreciate your support and will keep updating you folks as things pop up!
