Flat packing all the way! Just please give people a pre-sorted box of screws and a detailed instruction manual. Send it to some reviewers that way to get feedback on what could be more clear in the instructions.
Noctua just updated the L12s design, would u mind to test it out compared to the l9i?
Best Regards
Are you referring to the new taller L12S? Then I'm afraid that specific model will not fit with it's 70mm high posture =(
size L (05) would be good for slim custom loop watercooling, with EK SE 240 slim (26mm thickness) or alpha cool nexxos xflow (30mm thickness) + standard 25mm fan + XSPC ion pumpres combo (it's the most compact pump res combo, even if compared to ddc pump res combo) ,, still wondering for custom loop
is it still possible to watercool cpu and gpu with the part as mentioned above?
oh and i think flat packing is the best way to reduce shipping cost, and assembling the case also part of the art of building the rig![]()
The only challenge I see with the parts you mention is where you would place the XSPC ion, it is 50 mm wide (right?) so it would fit in the GPU chamber which is 51.75 mm wide (see specifications here: http://louqe.com/files/specifications_ghost_s1_MkII.pdf ) in front of the GPU. You would need a short GPU i guess.
We are hoping to announce the countdown within two weeks.When is estimated pre-order currently?
ahh, I forgot to mention the GPU that I'm gonna use, i have palit gtx 970 jet stream and EKWB full cover water block (short type GTX 970)
https://www.ekwb.com/news/ek-introduces-short-type-geforce-gtx-970-water-block/
after replace the stock heatsink with the water block, the GPU length is about 20 cm, XSPC ion dimensions: 58 x 50 x 154mm
yes i'm planning to put it in the GPU chamber, my bad didn't mention my GPU earlier,
anyway, based on your test Li heat pcie riser is better than 3M right?
Does this case support 2x 120mm AIOs instead of 1x 240mm ?
Thinking of a dual-AIO setup with a Vega 64 Liquid and an L tophat![]()
Then you should be fine, but there are never any guaranties. If we were to add some mounting holes for a reservoar in the blade, what would be the best (universal) solution?
We can't say one riser is better than the other based on benchmarking results. The differences are small and within the error margins.
now I am waiting on this case while using a ml08 as a stopgap.We are hoping to announce the countdown within two weeks.
After some digging, I cut down my specs to an delidded i7 7700k and 1080 to keep the thermals in a more agreeable range.
Personally, the 8700k thermals are a bit overwhelming. and the 1080ti might add a bit more heat to the system.
