1 - If you don't want to bend a Noctua NH-L12S than the Big Shuriken 3 with the screw mod is probably best.
2 - I would think 2 x M.2 would be best for dual boot, unless you need insanely fast transfer speeds I don't see any reason for raid.
3 - I honestly have not had much issue with dust, I would avoid dust filters on cases this small as they are usually quite restrictive on airflow.
4 - I have a set of custom cables for my ghost from pslatecustoms, I think they are worth every penny. Look great and make cable management much easier. He should be opening orders again soon.
5 - One of the biggest problems with the 5700 XT is the width of the custom cooled ones, most will not fit in the Ghost. The Asrock Challenger and PowerColor AXRX will fit for sure, you have to make sure they are 45mm or less. The reference cards will all fit.
6 - A medium tophat with 2 fans as exhaust helps a lot with cooling.
hello i tested the BS3 and it doesnt fit with any motherboard on the gigabyte x570 I for instance the socket is to close to the back I/O cower so you can not slide down the side pannel dont know about the asus strix i just got itHi,
A year and a half ago I built a new PC, I was eyeing the Ghost S1 but it wasn't available (and now sadly still seems hard to get).
I recently got rid of it for many reasons; I wanted something smaller (than my h400i), I don't like RGB's and all that jazz, I don't like water-cooling AIO and I use macOS most of the times and don't actually game all that much.
Now knowing what I need, I would like to rebuild a computer inside the Ghost S1, however I could really use some help.
-I would like to go Ryzen 3700X Air Cooled. I will make some research to make sure it is compatible with macOS but I think my motherboard of choice for now would be the ROG Strix x570-I Gaming. Is there anything I should be concerned about when choosing the CPU Cooler with this motherboard? I am leaning toward the Big Shuriken 3 (with the screw mod).
-Can I have 2 NVMe SSD, one with macOS and one with Windows? Or can you only install them in Raid?
-How do you deal with dust? When I look at the amount of dust that I used to get on the filters of my old PC, I am really worried about the Ghost S1 with all these holes and no dust filters.
-I will probably go with the SF600 (I fear 450 might not be enough if there is ever a high end AMD GPU). Do you have any recommendations for shorter modular cables? I feel most cables are way too long and would just be crammed inside an already tight case.
-Best 2-slot 5700 XT?
-Would this build benefit from a small top hat with 2 120mm fans? I find the case so beautiful without any hat, but the only one I can tolerate is the small one.
What would be the best option for quiet fans? (I don't mind something slightly less efficient if I can avoid those brown Noctuas).
Thanks a lot for any help !
Hi PaulI have the black ridge with both noctuas 92mm and 120 x 15mm and forget about cooling a 3900 at 1.25 or similar.
I have a 3700x at 4200 and 1.28v and it gets to 96 degrees within seconds at prime 95 small fft. It gets to 86 degrees on a single cinebench r20 run. That with the case opnened. I guess the 3900 is going to be even more diffcult to cool down
On stock it cools the cpu well because it goes down to 3900 mhz or so and 1.05v when using all cores.
It´s more or less the same story with big shuriken 2 (old one, adapted) and the idcooling is-60, being the big shuriken worse and the idcooling slightly better with just one 120x15 noctua (and being slimmer) The good thing about the id-cooling is that it´s very slim and with the 15mm fan over, it has roughly the same height as the black ridge with just the 92mm fan, I thought it was going to be a "meh" cooler but it´s quite good. Black ridge is also good, but I think it has too little mass and it heats up and down very very fast so the fans are always changing speeds and that fact makes me mad. The is-60 has a big chunk of alluminium over the cpu coldplate and I guess that helps stabilyzing temperatures.
smallformfactor.net
Totally agree about the IS-60. I am using one to cool a 3600x in a SM550 and it does a very good job, I did replace the fan with a Prolimatech 140mm Slim Vortex. I think a lot of people pass on this cooler because they aren't expecting good results which is too bad because at it's height it is very good for several SFF cases. You could even use a 25mm fan with one in a Ghost but that would put it very close to the side panel.I have the black ridge with both noctuas 92mm and 120 x 15mm and forget about cooling a 3900 at 1.25 or similar.
Hi Paul
i stated that: '' i currently run mine 3900x on 1.25V 4.2 solid all cores that seems to be comfortable with a custom water loop ''
@ 70 deg not in cinebench but in a real render scene in Vred that seems to push the temperatures a bit up in cinebench its around 67
nowhere i stated that you can run it wit the black ridge. the top for black ridge was 4 ghz at 1.06
i had the fans on the black ridge facing inside, didnt test the other way around.
also wich board are you using? try to turn up a notch the LLC dropof for me the Gigabyte bios update to ABB fixed sudden drop with vcore under load the LLC than you should be able to decrease the voltage. On asus this problem shouldn't be an issue if you believe the internet
i just uploaded my spex to the forum:
Ghost S1 custom water build
Hi guys i wanted to share my experience with the ghost s1 custom water loop. Since i only found one online and that had very little resources. Here are some pictures of it: https://www.flickr.com/photos/184686021@N08/ its all made from of the shelve parts and a custom made water cooling holder...smallformfactor.net
I also render (with vray) and after I finish this first weeks of trials and errors, I guess I will stay somewhere around 4ghz because of high temps. After experiencing this, (at least in my case that I like to overclock) I really think that watercooling is mandatory if you want to extract good processing power out of these cpus on a small case.
where do you have this information from?Wait till October and you'll be able to purchase it from Amazon Germany. I'm from Spain too and that's what I'm going to do.
good to know i w8 because the import duties in europe on amazon.com are horrific...not OP, but read on their twitter:
i'm basically waiting for it as well.
if the tubes are kinked that could lead to limited waterflow that could limit the cooling performance, and lead to leaks of cooland (total rip off) but if you dont open it regulary probably the coolant degrades before you encounter these problems.I saw a video of someone putting the Fractal Design S24 inside the Ghost S1 is there any problems with tubes getting kinked because the tubs come out of the top of the block?
Is there any problems with using the cpu cooler?
will need to test first but as for thermals the black ridge with noctua 12x15 and 9x14 combo is far supperior even though it cant keep the 3900x in check at stock (because there is no stock it keeps overclocking till it hits a wall).
Hello sorry for the late reply but weekend...Hi, thanks for the answer.
I was going for the Aorus X570 mini-itx, and already bought the BS3 sadly.
Does it not fit on the motherboard because something blocks the cooler installation or just the side panel cannot slide? If the issue is sliding the side panel somebody made a "hack" to get 1-2 extra mm so it can slide.
I am curious about what you are suggesting, is it a :
Alpenföhn® Black Ridge + NF-A12x15 + NF-A9x14 ?
No issues fitting that with the Aorus board?
Thanks !
i didnt know this was a thing i personaly would order the feet imediatly the should come as standard i wanted to make them myselfI just picked up a Ghost S1 Pangea and wanted to pick up some stuff. Namely a large tophat and a non-vented glass side panel like the ones outlined here in #5. Has there been any update on the side panels or when the Pangea tophats will be back in stock?
