SFFanatic
Also, he has a Noctua NH-L12 in his build--good luck finding one of those for under $150--in fact, that's the reason I sold my Ghost S1. I just couldn't justify spending another $150 on the build.
What's wrong with a Noctua NH L12S ?
That's suppose to be the Successor so i assume it would be either same performance or an improvement?
sffjawsh
NH-L12S doesn't fit the Louqe S1. It is agonisingly a bit too tall for it! You can bend the heatpipes and it does seem like it is easy enough, but not everyone wants to/is comfortable doing that. The old NH-L12 fits just fine but as @Engr62 pointed out, they're OOS almost everywhere.
Reactions: Engr62
Questors
130
86
How high can we build? Can't wait for someone to stack 10 Ghost cases up to the ceiling
That sounds like sarcasm to me. :p Some of us (by us I mean ME :cool: ) are stacking a bit with the tophats in order to achieve what we want to build. Of course aesthetics are in the eye of beholder. For me coming down in size from my elsewhere mentioned CaseLabs Merlin ST10 atop two pedestals to a Ghost (even with tophats) is an exercise in tiny.
SFFanatic
Does anyone know which has the most motherboard IO clearance for the Ghost S1 out of the Noctua NH-L12 and Scythe Big Shuriken 2 Rev.B ?
I'm slightly concerned about compatibility issues for air coolingdue to the rather large IO shields of the new x570 ITX motherboards:
Asrock x570 phantom gaming itx tb3
ROG Strix X570-I Gaming
Questors
130
86
This looks to have great clearances all around.
Gigabyte Aorus X570 I Pro WiFi
Something consider, If the actual measurements of the board are known, one may be able to calculate the distances and heights by measuring the picture and calculating a scale. I suppose it's worth wishing good luck with finding height measurements, but distances should be doable.
quetzacoatlx
103
62
I wish that ghost was available in say 3 different sizes rather than top hats. The case would look so much better without those gaps.
Agreed. S1 looks amazing without a top head, OK with the small TOP head, but ugly with the large one.
For S1 with the large top head, the switch position is too low, and the vents on the side panels lost their symmetry. The case doesn’t look like a unified one piece of work but two separate parts stitched together.
Rmorrison
144
128
I don't know. Three sizes would be nice and all but I saw a silver Ghost with a small tophat on bottom and a larger tophat on top. Both tophats were in black and it looked so sweet. If the ghost fit a 3 slot gpu I would buy it hands down.
Questors
130
86
I actually asked the Louqe team about this last year. Making different sizes like mini-ITX, mDTX and micro ATX. They said it would be too expensive. So cost is the prohibiting factor. This is why tophats are available.
Questors
130
86
would the new asus X570 mini dtx board fit into a ghost if a top hat is being used?
I have been told the riser length will not be compatible with the mDTX board. It will be too short due to the extra board length dimension.
I had the same idea until that was brought to light.
Reactions: Rmorrison
bolo_1221
Hey guys, the Big Shuriken 3 does actually fit in the Ghost S1 (with minimal but easy modification). Here is a link to the gallery:
The motherboard I use is the Asus z270i Strix and the fan is the NF A12x15 PWM. I didn't try to install the cooler with the fan that it comes with, but I measured the thickness of both and they are both 15mm thick.
The cooler and the Noctua fan actually fit without any mods, the only problem is the screws, which is why I decided to mount it from the bottom.
blindphleb
79
107
That's a big win for those that don't want to smash an L12S! How much does having the fan right on the grill make? Is turbulence an issue?
GerryMz
56
this is awesome, what cpu are yoou cooling ! mind throwing in some thermal benchmarks?
