Hello guys. I am currently working on a personal build, and I would like to know what is the smallest internal PSU available on the market that supports 150w. *My project uses an Mini-ITX motherboard.
First, I thought it was FlexATX (15 x 8 x 4cm). But after some research I found the Pico/G Unite + Meanwell (10 x 5 x 3cm) solution to be the smallest.
Is there any internal PSU available that is smallest that the Meanwell solution? Basing that I only need 150w, ithere might be, or not?
PS: i dont want to deal with powerbricks, so I need an 100% internal PSU as small as possible. And I dont need 6pin connectors, as I'm using a GPU that gets power directly from the PCIe (GTX 1050). I only need to power the MB, CPU, and one 2,5" SSD
Cheers
Cheers
