SFF.Network The first Intel Z390 board has been revealed, by ASRock
Dubbed the ASRock Z390 Phantom Gaming-ITX/ac, ASRock is the first to officially launch an mITX Z390 board, Intel’s latest chipset supporting the 9th Gen Intel Core processors that are right around the corner.
The stand-out features are the Thunderbolt 3 enabled USB Type-C connector, as well as the four USB 3.1 Gen2 ports (10Gb/s per port) at the rear, with an additional two USB 3.1 Gen1 (5Gb/s per port) at the rear as well, along with two more via the internal header for the case front panel. The M.2 heatsink stands out as well, with a heatpipe connecting it to the beefy VRM heatsink that covers the rear I/O ports.
Read more here.
Reactions: Ionrent
TheOfficialCzex
39
31
It'd be run from the motherboard, haven't got the ££ for graphics card yet....
You can use three monitors with this motherboard by utilizing all three display outputs: DisplayPort 1.2, HDMI 2.0, and Thunderbolt 3. You will need an adapter, such as this one, for the ThunderBolt 3 port if you do not have a monitor that is compatible with this output
