Completed STX160.0 - The most powerful ATX unit, in the world!
Hahutzy
252
187
Does anyone know what would happen if you actually made a zero-depth (as opposed to zero-width) bend relief? I know the panel can deform a little in that area, but would it weaken or damage the sheet in any way?
Aren't full-width sheet bends kind of zero-depth? Or am I misinterpreting what you mean?
What is the slot height from the bottom of the slot to the flange for the PCIe retention tab?
This is a good reference: http://www.protocase.com/pdf/How_to_design_enclosures_for_motherboard_based_systems_092010.pdf
Here's the dimensions I'm using for STX160.0:
0 horizontally is the middle of the nut for the retention screw
0 vertically is the top of the retention tab
And the expansion slots are spaced 20.32mm from each other.
The retention screw I have 4.5mm away from the inside face of the frame.
These aren't absolutely definitive dimensions, I didn't spend a ton of timing getting it perfect since this is a one-off project.
I was getting ready to write a post on bend order and press brake tooling widths like I said I would last update, but then realized I may be getting photos of the case on the press brake so I'll postpone that update.
So for now just a short photo update of some of the PEMSERT nuts getting installed. Enjoy :)
Manufacturing the case part 1: PEMSERT installation
The nut for the PCIe retention tab is about to be pressed in, but first the operator is making an adjustment to the PEMSERTER press.
Something to note, the nuts are being installed prior to bending here. It's easier to install them in the flat sheet but if the fastener would interfere with the press brake tooling they can be installed after bending also.
The operator is about to move onto the next hole, but first he needs to place a new nut in the anvil (the bottom piece).
This particular anvil looks like is has been modified. Notice how it isn't completely circular, but instead there is flat cut into the outside circumference. This was probably done to allow nuts to be installed closer to a flange when they're being installed post-bending.
Next the hole in the sheet is positioned over the shank of the nut, then the operator depresses a foot pedal, which causes the punch (the upper piece) to come down and press the sheet down onto the nut and anvil. This force causes the metal to cold flow into the groove in the nut, locking it into place.
In the background the nut that was installed earlier is visible.
Then the process is repeated.
One thing I hope is clear from seeing PEMSERT fastener installation in reality is that there has to be room left for the tooling when deciding where to place fasteners. This is part of why it's important not to place them too close to bend lines, because if they have to be installed post-bending there has to be enough room between the PEMSERT and the flange for the anvil or punch to fit.
Relatedly, this is why PEMSERTs can't be placed really close to each other, the installation tooling has to clear the adjacent fasteners.
Another note, the threaded nuts are small and look similar to each other. So you can imagine how difficult it'd be for the operator to keep track of which goes where if I had specified a mix of M2, M3, M4, #4-40, and #6-32 nuts in this one part. So in addition to making sourcing screws easier, using the same thread size as much as possible across the case will minimize errors when installing the fasteners as well.
Well, that's all for now. I'm hoping to get pictures of the press brake before writing that update and I'm stalled on the power supply situation so the next update may take a few days. I've yet to hear back from HDPLEX and I'm still waiting on a PICO-BOX Z4-200-ATX I ordered as a backup plan.
Table of Contents
Next Update
thejestb
I'm using 1.27mm stainless, which is close to your 1.29mm thickness, so I was just wondering, what screws are you going to use that don't have a way too long countersunk depth? All the options I looked at are countersunk far too deeply...
1.3mm sheet is just thick enough for standard 90° countersunk M3.
I hope this illustrates it well enough:
Gotcha. There could be some distortion but I don't think it'd damage the sheet.
I use 1/2 the material thickness as the depth of my bend reliefs and that's worked well so far.
Hahutzy
252
187
This is how my reliefs are for prototype v2.
1/4*thickness relief width
0 relief depth
(in v1 I used 1/2*thickness for both)
I guess you'll eventually get a definitive answer to this question. ;)
Any particular reason you switched to 0 depth bend reliefs?
Hahutzy
252
187
Just because the relief depth takes away from the aesthetics.
I'm using my next prototype to test 2 things. First one is whether 1/4 width + 0 depth relief work for bends.
The other one is that, in solidworks, the M3 countersink holes are by default 6.3mm diameter going down to 3.2mm diameter. But 90deg screws that I've seen are only 5.4mm wide max. In my first prototype, after installing the screws, you still see the countersink hole quite obviously.
I shrunk the M3 countersinks to 5.8mm to see if that is still enough tolerance while minimizing how much of the countersink hole shows after installing a screw.
Lone
Lone Industries
Feb 25, 2015
731
1,246
loneindustries.com
This obviously differs from manufacturer to manufacturer and the tooling they're using, but from my experience 5.8 mm (82 degree tool) just barely works with 5.4 mm diameter M3 flat head phillips screws. Head sticks up just slightly. Okay with anodizing, but definitely too small if you're powder coating the parts.
Hahutzy
252
187
Thanks for the insight Lone. I think I will be trying 6.0mm instead of 5.8mm because I do want to leave some room for white powder coating being an option down the road.
Colinreay
198
490
Aibo, thank you so much for this! I really want to do some custom cases for a computer club I'm in at my high school, and this build log also doubles as the best guide I've found yet for making a case.
I still have yet to find a good accurate 3d model for a gpu and motherboard (like the ones from the component selection) for Fusion 360. I've been trying to model my own following the PCIe spec, but the diagrams are spaced out and pretty confusing.
Still, I can't wait to learn more, and this forum literally seems like the place I was wishing for.
Hype!
I also got pics of the sheet metal getting bent so I need to write that post first. So ya'll have to wait for pics of the case until I'm done with that :p
And @jtd871, I got lucky and there's pics of them bending the retention tab so you'll get to see exactly how it's done.
Last update you got to see some of the PEMSERTs being installed, this time it's all about the bending.
Manufacturing the case part 2: Bending metal
I talked about how press brakes work and modeling the case with them in mind in Designing the case Part 2. Now it's time to see an actual press brake in action!
And I just can't do an update without explaining something so luckily this also is a great way to demonstrate bend order and press brake tooling length :p
Real quick though:
PEMSERTs (will we ever stop talking about them?!)
I honestly thought I was done discussing self-clinching hardware last update but with these new pictures I realize I made an incorrect assumption previously. It's hard to see, but actually only a few of the PEMSERTs were installed in the sheet prior to bending:
Notice how the other holes are empty.
The reason for this is that several of the nuts would interfere with the press brake tooling so it doesn't make sense to install them all now. The hardware that was installed will interfere too and will have to be worked around, but it's done anyway because these seven PEMSERTs will be difficult to install post-bending.
Bend order
So bend order is exactly what it sounds like, it's the order in which the various required bends in the part are performed. This will mostly be up to the manufacturer to figure out the best order to do the bends, but it's useful to understand the concept to avoid certain design choices that would unnecessarily increase the number of different bends required.
Quiz time again! Before scrolling down, here are all the bends for the base of STX160.0, which order do you think they'll be done in?
Ding, ding, ding! Time's up, pencils down.
Did you answer something like this?
That seems reasonable right? But each additional bend means more time both in setting up the machine (selecting and installing the tooling, programming the machine, etc.) and actually performing the bends. Time is money though so the former will mean a higher setup fee and the latter will mean a higher price per part. Also, each additional bend increases the chance for error.
So it's generally more cost effective to form the part with the fewest operations possible so the actual bend order would look something as follows:
Note how all 3 flanges on the top and then bottom edge of the flat pattern are formed in one operation. This reduces the number of bends from 11 to 7.
This is why it's useful to keep flanges on adjacent sections of the part inline with each other so they can all be formed in one go.
First bend
So how is that actually implemented? To start with, let's look at the first bend getting formed.
First off the operator checks the drawings provided by the engineering department. He's checking for things like what bend radius is called for, bend angle, etc.
It's a bit hard to see, but notice how the bottom face of the middle section of the part in the 3D wireframe drawing is labeled "GREEN SIDE". While the part is still flat it's not always obvious which side of it will end up as the outside and which will be the inside. So they've marked one side of the part with a green marker so the machine operators can keep track during the various operations where it matters, like installing the PEMSERTs and bending.
Next the operator starts prepping the press brake by loading the needed dies (the bottom v-shaped piece) and positioning the backgauge (the mechanism on the opposite side of the part from the operator that the part is pressed up against).
Make note of the backgauge, we'll come back to its importance in just a bit.
The punch (the top piece above the part) is now installed and the operator is about ready to bend the retention tab for the video card slots. Visible in this picture is that green mark I mentioned earlier.
And voila! STX160.0 now has its first bend and is no longer just a flat piece of metal :D
Then it's back to the drawing to check that the flange is the correct length. Drawing calls for 0.472in and actual is 0.472in, not bad! :cool:
The bending process is imperfect so it's important that the manufacturer perform constant checks to ensure the parts are being produced to spec. If the punch or die used is incorrect, or the backgauge is not set correctly, or the operator doesn't have the part pressed firmly against the backgauge, the part may not end up at the intended dimension.
Backgauge
Remember how I said to pay attention to the backgauge above? If you forgot, go back and watch how it's used in the GIF.
The backgauge's primary purpose is making sure part is positioned under the punch where it needs to be for the bend to be formed in the correct location. To do so, the operator pushes the workpiece firmly against the backgauge fingers and holds it there until he presses the brake's control pedal and the punch comes down and makes the bend. In this particular bend operation it controls the distance between the far edge of the part and the punches, which I've marked with arrows.
Note how the edge of the part is parallel to the bend being formed. This is important because not all manufacturers will have fancy multi-axis CNC backgauges, in fact the one on this press brake is a simple manual backgauge. I hope you can visualize how it'd be more difficult to setup the backgauge if I had designed the case such that the edge it's currently pressed against was tapered at an angle instead.
So in general, try to ensure the edge of the sheet opposite each bend is parallel to that bend and that there is enough continuous edge to press the part against the backgauge fingers without the part slipping.
That does limit the design to rectangular boxes though so if angles are desired to make the case more visually interesting, discuss it with your manufacturer to make sure it doesn't make it too difficult to accurately bend the parts.
Bends 2-5
I don't have pictures of the other bends for this part so I'll mock it up using this wonderful press brake model I found on GrabCAD.
So something like this arrangement for Bend 2 would allow all three flanges along that edge to be formed in one go. And with some rearrangement of the punches to clear the studs on the other side, the flanges on the other side would be formed in Bend 3.
Then Bend 4 and 5 would be done.
For Bends 6 and 7 note how it's the flanges formed from the previous two bends that are pressed against the backgauge.
For the last bend in a part like this, keep in mind the issue I talked about when I went over press brakes about the opposite flange hitting the punch, punch holder, or other parts of the press brake:
Luckily the proportions on STX160.0 are such that there's nothing to worry about :)
This is also why these inside bends are done last, if Bend 4/5 were done last then the part would interfere with the press brake for sure.
Brake tooling width
You may have noticed in the above pictures and screenshots that the press brake punches come in different "widths". They are what's called sectionalized tooling, which is to say that rather than having one really big punch (or die), they're sold by the tooling companies in sections of various length (which is what that dimension is called for press brake tooling, not width).
Having a diverse library of punches and dies in various lengths and bend radii is necessary to make all the different bends. In the above image, rather than one bigger punch, two smaller ones are needed to have a gap around the nut that's installed in the retention tab of the case. Also, if you look closely you'll notice the punch on the right is slightly shorter ("narrower") than the other, so they're two different lengths.
I bring this up because press brake tooling is expensive, even just a small set of quality punches can cost many thousands of dollars. So it's important to select a sheet metal fabricator that has the punches needed to make your case with the bend radius desired because buying them just for a small run isn't practical.
STX160.0 has evolved!
From a 2D sheet of metal to a fully formed enclosure. I don't have pics but after the bending was done the case had the rest of the PEMSERTs installed and then it was tumble finished.
Bonus content: The Folder
So I've talked quite a bit about press brakes over the course of this build log, but those are actually just one type of machine for bending sheet metal. Swing bending machines are another type that are used in sheet metal shops.
This swing bender is a Schroeder SPB Evolution UD, but the shop just calls it The Folder.​
Swing benders have the advantage of being quicker to setup and they are better for large parts since the operator doesn't have to support the workpiece during the bend.
The disadvantage is that they are not suited for small parts, or for complex bends, or when bends are need in the middle of the sheet (like the retention tab from earlier).
So that's sheet metal bending, hope you all enjoyed the pictures and animations showing how it's done.
Table of Contents
Next Update
5,570
4,778
It's coming along nicely ! So in real time you're probably already running a system inside ?
Not yet. I've been busy and I'm still waiting on the Pico BOX Z4-200-ATX :\
I must be learning a lot. I almost correctly guessed the bend order (aside from reversing 2 and 3, which, to be fair, seem to be commutable, as are 4 and 5 and 6 and 7)
2-5 could really be done in any order, though usually 2/3 and 4/5 would be done in pairs since they require similar tooling setups.
6 and 7 have to be done last since it's not practical to bend 4 and 5 after them.
