Completed STX160.0 - The most powerful ATX unit, in the world!
Where other, lesser ATX units need you to hook up stuff like a motherboard, video card, and storage drives to it and put it all inside a case to be functional, the mighty STX160.0 is a fully operational battle station gaming computer right out of the box!
Backstory and initial parts selection
Since the first Mini-STX boards were shown off at CES earlier this year I had been toying with the idea of doing a really small build with one. Part of my idle daydreaming was fitting one of these boards into an old ATX power supply just to make a point of how oversized the form factor is for today's hardware. It'd be possible to fit a motherboard with a socketed Intel CPU + storage + power supply in a power supply XD
[Edit: To be clear, I'm not taking credit for this idea, @slipperyskip did this way back in 2003. I'm just building a system in a PSU that is actually decently specced :p]
But CES came and went with still no real indication of when we would see these boards on the market, or if they would even be available at all or just limited to OEMs. Computex didn't really improve things and I forgot about the idea.
Two things that happened within the last few weeks changed things though and that old idea came back with a vengeance!
First: The NVIDIA GTX 1060 launched and the mid-range Pascal card delivers GTX 980 levels of performance while only drawing 120W at full load! And the reference PCB is short to boot! :cool:
Second: ASRock announced their H110M-STX board and they specifically mentioned that the M.2 is wired with PCIe 3.0 x4 to the CPU. With a 3.0 x4 connection to the processor, that meant a M.2 to x4 slot adapter should work (in theory) and it'd be possible to hook up a video card to this tiny board with minimal performance loss!
Then it was just a matter of figuring out how to connect everything together and power the board and video card. Right off the bat I knew this thing had to have an internal PSU. No way was I going to build a PC inside a PSU but cheat by using external power bricks :p
A bit of research led me to the Bplus P4SM2 for the M.2 to PCIe x4 slot adapter and the HDPLEX flexible PCIe extender. The P4SM2 is a bit pricey but from what I was reading it's the only adapter proven to work reliably by people using them to add external GPUs to Intel NUCs (before doing the same over a Thunderbolt connector became feasible). The HDPLEX extender seemed good because it's not overly long, is extremely flexible, and @iFreilicht had good luck with it in his testing.
Normally going to all this effort to hook up a video card to a Mini-STX motherboard would be a stupid idea because Mini-ITX isn't really that much bigger, but Mini-ITX has one big disadvantage for what I wanted to do: ITX boards are 170x170mm but the ATX PSU form factor is only 150mm wide :p
Next was power, and once again I turned to HDPLEX, selecting their 160W internal AC-DC adapter to convert incoming 120V AC to DC. It puts out 19.5V DC and conveniently the H110M-STX needs 19V DC in for power (the 0.5V different shouldn't matter, it's common for laptops to have a 19V label but come with a 19.5V AC adapter). The video card needs 12V though so I'll be pairing the AC-DC adapter with the HDPLEX 160W DC-ATX unit. The ASRock doesn't have an internal power connector (just the 5.5mm x 2.5mm barrel connector on the back) and the HDPLEX 160W DC-ATX doesn't have a PEG connector so I'll have to cobble together a wire harness but otherwise it should work.
For the video card I ended up selecting the EVGA GTX 1060 SC Gaming. It's short, reference height, single 6-pin power, and with a BIOS update, semi-fanless functionality. Check, check, check, and check. Unfortunately it's been out of stock every time I've checked for the past two weeks but it's finally showed up on Amazon for pre-order with an in-stock date of August 19. I put an order in but we'll see if that date holds true.
Storage I'll figure out later once I have a better idea of how much space is leftover.
So that just leaves CPU and RAM.
RAM is an easy choice, 2x8GB of DDR4 SODIMM. While the performance benefits of dual channel over single channel is minimal, 16GB is plenty for what I'll use this for and I don't think I'll ever upgrade it to 32GB so it makes more sense to just get two sticks. The Crucial Ballistix Sport LT looks good (in the pictures at least) so I had ordered a set of that.
For the CPU, I am limited to the 35W T-series SKUs since: 160W (HDPLEX) - 120W (GTX 1060) = 40W for everything else. The HDPLEX 160W AC-DC can do 195W max but I don't want to push it since ventilation in this thing isn't going to be great.
The T chips are aimed at OEMs for microtowers and AIOs though so they're not readily available, especially the 6500T, 6600T, and 6700T. At least not without paying a hefty price premium. So it seemed like a stroke of luck when a used i7 6700T popped up on eBay for $260. Instant purchase :)
Unfortunately both the RAM and that 6700T ended up being defective in a mess that took several days to completely troubleshoot. And to add insult to injury, it turned out that what looks like a heatspreader in the pictures of the Crucial Ballistix Sport LT DDR4 SODIMM is actually just a sticker :\
So while I would have love to have an i7 in here, even if it's the lower-clocked T-version, I just couldn't justify paying $360 for a new one. In the end I went with the i5 6400T and a kit of Kingston HyperX. Luckily both of those have passed an overnight run of Prime95 with no errors. Lesson learned though, modern RAM and CPUs are very reliable, but it still pays to test everything just to be sure.
With the parts list mostly squared away it was then a matter of figuring out the housing. At first I thought I could squeeze everything into a 180mm ATX housing but after mocking things up in SketchUp it quickly become obvious that wasn't happening...
Whew, that's enough writing for tonight! :)
Table of Contents
Next update
QinX
kees
Mar 2, 2015
541
374
This is super cool!
This is the tiniest of the tiny gaming systems and with the 1060 you can play anything with good settings @ 1080p.
Just curious, what about the front IO? I'm seeing rear IO and a PCI cutout through the vents. But then the front side gets a C14 plug only?
Or is this just the mock up you made and you are actually going with a different design?
Great concept.... but will it all fit?
I hope so! It all does in the CAD model but only with 2-3mm to spare.
Wow, just wow ! I wish there was STX for LGA1150.
That'd be nice for downsizing a current system.
No water cooling though so still not as cool (hehe) as H2O Micro :p
The IO arrangement is strange but it will all make sense in the second act of this project ;)
QinX
kees
Mar 2, 2015
541
374
My guess is that you're going to re-route the with short cables. But I'm really looking forward to seeing this. This might actually make a cool upgrade for people who have behemoth cases that have dual PSU mounts. Now they can actually make a semi reasonable use out of that :D
jtd871
1,166
848
This concept almost makes me regret buying an A4 case. I await your next steps with interest and impatience.
I'm also a bit surprised that a boutique builder hasn't let something like this leak out of their skunkworks...kudos to you if you can pull it off!
Reactions: Soul_Est
This is just something a personal project I'm doing on the side because I think it's cool. While people may like the idea of a full gaming computer in an ATX PSU form factor, the limitations and tradeoffs are pretty big. So it's unlikely this will ever go to production.
This has been technically possible for a while with a NUC. But I want the bragging rights of having a socketed CPU so that's only become possible very recently with the release of Mini-STX boards.
Reactions: Soul_Est
jtd871
1,166
848
This concept almost makes me regret buying an A4 case...
I did say "almost".
I recognize that there are significant challenges with this design approach, but the possibilities for builds like this becoming an actual thing in not too short a time frame are exciting.
Looking forward to this, I can't wait to see how you got this to fit inside of that very constrained box.
It's a very strange layout for sure.
I'm hoping for a pretty quick turnaround on this project. We'll see.
As mentioned at the end of the intro post, after I had figured up a rough parts list I set to work mocking things up in SketchUp.
I want to detail my process of going from idea to finished CAD model that's ready to manufacture so grab your beverage of choice, this will be a long post (actually posts it turns out)!
Designing the case part 1: SketchUp
The whole point of this project is to fit a complete computer within the dimensions of an ATX PSU-sized housing. So my first step was to double-check what those dimensions were. The form factors of standardized things like ATX power supplies, Mini-ITX motherboards, PCIe cards, and so forth are typically defined by long, technical spec sheets. Many of which are available from formfactors.org.
Strangely they don't have the newest ATX revision v2.4, but luckily @EdZ has uploaded a copy to the Resources section since it's no longer available from Intel's site either. The physical dimensions haven't changed in many years but it's good practice to work with the latest version of a spec.
Few things of note though, while it's good to adhere to the spec as much as possible to maintain compatibility, it's also necessary to be aware of how other manufacturers deviate from it in practice to make sure whatever you're designing will work in the real world.
For example, the ATX spec officially only allows for a housing with a 140mm depth. But anyone who's shopped for ATX power supplies knows that almost all the higher-end units are 160mm deep or more. What's going on is that most enthusiast power supplies are actually using a combination of the ATX and the Entry-Level Power Supply (EPS) specs. Entry-level in the context of server PSUs BTW, it's actually meant for higher wattages than ATX and because of that it allows for much longer depths, up to 260mm I believe.
The height, width, and mounting holes are the same though so I'll just use the figure 12 from the ATX spec for reference.
Another deviation is the mounting tabs visible at the front edge of the unit in the diagram. I'm not sure if it's an optional part of the spec or not, but either way, nobody ever implements it in consumer units so adding support for them in a consumer case is pointless.
So with that little lesson out of the way, what are the dimensions I have to work with? Well, it's 86mm height x 150mm width x ? depth.
Now that I've used "real" CAD programs, I don't think that SketchUp is the best program for designing a case. It's really meant to be used as the 3D equivalent of a paper sketch (hence the name) and while people have done really cool things with it, a proper solid modeler with sheet metal support is much, much better suited for designing a case. That's a topic for another day though.
But for quickly roughing out a layout, it's the perfect tool for the job, so SketchUp is still where I usually start with a case design.
Here I've made a simple wireframe outlining my starting dimensions. The height and width are locked in but the 160mm depth is just a starting point until I get mockups of the parts in there and starting figuring out how much room I'll need.
Next I dropped in a very rough placeholder for the Mini-STX board and a PCIe video card from subtec's excellent precise blank model, modified to the length of the EVGA GTX 1060.
And duh, a video card that's at least 172mm long won't fit in a case that's only 160mm deep :p At this point I was still thinking I could take a dead ATX unit and mod it. The next common size up for ATX units is 180mm so I adjusted the model and continued to add placeholder parts.
After mocking up the two HDPLEX units, it became obvious that 180mm wasn't enough either. 200mm then?
Success! Or is it? It's tempting to think this will work since the parts fit within the outline but that's an easy mistake to make. Manufacturer dimensions for video cards are notoriously unreliable so it's naive to assume the card conforms to the official dimensions in reality.
Not only that, but the available space will be reduced 1-3mm in each dimension due to the thickness of the panel material. There's also manufacturing limitations like bend radius, minimum flange length, available standoff lengths, etc. that have to be taken into account. I'll go into those issues later.
Plus future you that has to actually assemble this thing will curse past you who designed it if you don't include a bit of wiggle room around components for installation.
The other limitation I ran into is that I did not want to permanent modify either the motherboard or video card. This is just a project I'm doing to see if it's possible and I will probably sell many of the parts eventually to recoup costs so I want to keep them in resellable condition. Problem is, the ASRock H110M-STX does not have an internal power connector, it only has a DC jack on the rear. I want to avoid having a power cord sticking out of the case and then running back inside to connect to the HDPLEX so that meant the rear IO had to be on the inside.
As can be seen in the above pic though, that means there has to be enough space between the HDPLEX AC-DC unit and the board for the power connector to fit. A quick look at the available right-angle 5.5mm x 2.5mm plugs though showed that I'd need about 20-30mm of clearance. This has the advantage of allowing for longer video cards if I want to upgrade and will allow space to tuck cables and work in the case.
Quick aside: It's easy to get lost in the 3D model because you can zoom in until the tiniest detail fills the screen. It's important to keep in mind the physical size of what you're designing so you don't end up in the situation of what looks like a huge gap in the model turns out to be way too small to fit your hands in so you can't easily work in the chassis without lots of cursing, sweating, and possibly gaining a few scars.
For example, it looks like there's lots of wasted space in the above pic when I increase the depth to 230mm. But really that's only 30mm, typical USB plugs wouldn't even fit in the back of the motherboard without seriously bending them!
Anyway, now I had to make a decision. Up until this point I wasn't sure if I would just get a custom case made from scratch or mod a dead ATX PSU for maximum sleeper PC cred. 160mm-180mm units are very common so dead ones are fairly available too.
200mm+ ATX units is typically the realm of high-end 1000W+ power supplies though, so they're much rarer and thus dead ones that I could pick up for a reasonable price are much rarer too. 230mm units are particularly uncommon too and that's the depth it was looking like I'd have to do to have room for everything.
After poking through eBay listings for a day or two I decided to just go for the custom case. I'm lazy so if I could just push pixels on a computer screen and let someone else do the dirty work of cutting and bending metal then that's fine with me :p
With that decision made, I needed more accurate models of the parts to better figure out the layout so I could start designing the chassis. Here's where SketchUp really shines, I've been using their Match Photo feature for years and it's awesome for this. Basically you import a picture into SketchUp, tell it where the perspective lines in the image are, and then you can model over top of it. And of particular importance for this kind of work, you can input a dimension for a known feature, and it will scale the whole model to match. Example animation with the P4SM2 here.
So I used Match Photo to make models of the motherboard and P4SM2 to continue testing layouts. Here I'm experimenting with putting the AC-DC up high and the DC-ATX in the corner to maybe make room to run short extension cables from the motherboard's rear IO and the case.
It was quickly becoming apparent though that any future decisions for the layout would be dependent on the specifics of the case. So my time with SketchUp has come to and end and in part 2 (and maybe part 3 at this rate) I'll go over some of the details of designing a sheet metal computer case.
Stay tuned!
Table of Contents
Next Update
5,567
4,778
That looks like quite the puzzle when the CPU heatsink is added !
Just a suggestion, maybe you've thought about it, but you could flip the motherboard so it could ventilate from the bottom, maximizing cooler size potential, like a Scythe Big Shuriken 2 rev. B.
