1. Remove bottom dust filter, it's a major choke and it helps
2. I haven't tried it personally cause in my case there isn't that much space (GPU is properly massive but wanted to do so and i believe it should help. Position another fan to move around the stale hot air produced by the card somewhere on the back.
It is actually meant to come off as you can see in the manual, is just not well implemented and it does get damaged quite easily. Just another thing that disappointed me.Thanks for the reply. I can have a look at putting a fan on the inside of the front panel. As for the bottom air filter, I don't want to remove it since it's not meant to come off and would be destructive. Don't want to sell a damaged case in a few years.
Suggestion: go for an AIO or change caseHello. Does anyone know of any guidelines I can use for undervolt my 9900K?
My motherboard is an Asrock Z390 phantom ITX and I'm having very high temperatures on this chassis.
As a heatsink I'm using a Thermalright Silver Arrow ITX-R, I thought it could be better than the U9S, but now I'm not so sure...
Suggestion: go for an AIO or change case![]()
I think that could be a solution when I look at the DA2Or I could also shoot myself and in the process solve other problems...
Which temps are you getting? I am now using an U9s with 2 fans intaking air, one 140mm fan on the side exhausting. 9900K 20mv undervolting and an ASrock Z390, and my temps are really good!Hello. Does anyone know of any guidelines I can use for undervolt my 9900K?
I'm wondering if the Sapphire Pulse RX Vega 56 fits inside a DA2?
The website of DA2 says it supports Dual Slot, 330x150x50mm cards. The Pulse Vega 56 is 282x125x55 mm.
50mm vs 55mm. Looking on pictures it seems there is still a tiny bit of space inside the DA2 to fit a graphics card that is slightly bigger than 2slots.
I checked again an the height of the Pulse seems to be 50mm, not 55mm as I initially stated in my previous post. Might this maybe work?No, the frame of the case will obstruct the excess verticle size even if you decide to remove the dust filters and their acrylic brackets. Most likely won't be able to insert it in the PCE slot for a few millimeters
Well, I have ordered a Noctua 12 slim fan, it will arrive next week, I will do these changes then, because this case is no easy for work, you know.try to remove the 92mm fan, and flip the 120mm fan in the Silver Arrow to have a flow from left to right...
Actually is not so bad to work with it with air coolers after tried custom loop!Well, I have ordered a Noctua 12 slim fan, it will arrive next week, I will do these changes then, because this case is no easy for work, you know.
Thanks
This is my actual orientation, with the two fan Intaking form the back, and exhausting with the 140mm fan.@fabio I am re-reading the thread and I see that you have used the U9S with airflow in both directions, but it seems that to the right (toward the front) is the most effective, please can you confirm?
BTW, I have received the Silver Arrow 130 Plus. I will test it end of next week with a Gentle Typhoon PMW fan, comparing it with the U9s!
