Some pictures:
2 ways: carefully realign the motherboard brackets or if that doesn't work/it's possible, reduce a connector like I did here:
For the PSU, just use 2mm washer, they solve the problem! About the DisplayPort, I agree, but for example, my EIZO cable, that is thinner, worked with no problem! Other DP cables don't, in my case.I just had to do the same damn thing for my RTX 2060! Not impressed, Streacom. The metal SFX bracket also wasn't the best either. The screw holes didn't quite align exactly with the Corsair SF600, so one screw had to be slightly misthreaded.
Very helpful, thank you!For the PSU, just use 2mm washer, they solve the problem! About the DisplayPort, I agree, but for example, my EIZO cable, that is thinner, worked with no problem! Other DP cables don't, in my case.
I had a look, but I didn't get a metal file with my DA2... maybe Streacom should include one for revision 2I solved this issue in another way, cutting and filed the border:
Cool!
Well, I just would like to know the temps under Prime 95, latest version, with an OC of 5ghz and AVX offset of 3, or everything in AUTO in the Bios with MCE enabled (I don't know which motherboard you have). Is it possible for you?
So, you have the Fan blowing air from right to left, is it correct? Any other intake?
Thank you!
Once I installed this drive, the motherboard seemed to short out again (it powered on but it reset a couple seconds later, stuck in a loop). I took the screw out and wedged a plastic pen lid under the rail to hold the M.2 drive down. This time it booted fine. I put the screw back in but this time I didn't screw it too tight and the PC still booted ok.
So I can only conclude it had something do with the installation of this drive. Possibly the M.2 screw was a little too tight, or perhaps the M.2 drive was at a slight angle, causing it to be too close to one of those silver screws above and below the drive? I haven't had a problem since, but I wonder if anyone else has had a similar issue.
Is this a repeatable problem? I mean, screw down the M.2 drive tight and it goes into a booting loop while screwing not as tight will make it boot right up?
I've had this happen where the SSD shorts out some components on the motherboard underneath it. This might be what is happening here and might explain why the issue only arises when you tighten it down fully.
Yes, I confirm that the ASRock Z390 is not a great Ram Overclockers with 16gb modules.Thanks for the replies, I'm a bit afraid to mess with it as this build has been a bit frustrating already. After further investigation, it's possibly a RAM timing issue where the BIOS itself was restarting the system to adjust for stable RAM settings. I will post a separate thread so as not to hijack this one.
I am working on a signle/dual radiator NCASE M1 as well.Slimmer than the Noctua, but kinda the same performance. It would help if the mobo has some compatibility issues with the U9S.
On another topic I'm unhappy to report that i've started to give up on the DA2 and looking up other case options that can house the FTW3 with better cooling performance.
I am currently checking out the new Deng F15. See if it is your cup of tea?Slimmer than the Noctua, but kinda the same performance. It would help if the mobo has some compatibility issues with the U9S.
A sample build:- https://www.chiphell.com/thread-1955925-1-1.html
IMHO, solving or tolerating a dust problem is more easier than a thermal one, especially in the context of small cases. And, thermal problem is most often the paramount issue, especially for small cases (rather than dust issue or cable management issue).I've gotta say, definitely like the looks of this case, and the two bottom fans will sure help with the 80+ degrees GPU. I'm not sure how the air will flow in it though. And looking from the back bottom and top it feels unfinished, massive gaps on the gpu slots, massive top and bottom grates. This will be one to clean every other day![]()
Come to think of this, when reading all the build threads here, I notice there are many more people who say ''I need to find a case to give me better thermals'' than people who say ''I need to find a less dusty case''.
Anyway, back to the Deng F15, its main design goal is to provide max air cooling (for the current window side panel) and that is why there are so many massive openings. I reckon, the two 140mm intake fans will render the case to be positive pressure. Therefore, putting a filter at the bottom (not so restrictive as the DA2's) will keep the dust issue at bay. Additionally, each opening is large enough to let air escape easily (not so restrictive as DA2's) without the need for additional exhaust fans. This is just my theory. I am looking for some builds with internal exhausting display cards as I really want to see how if the case's numerous massive sized openings can give good thermals.
I personally quite like the minimalistic design though.
