Cool! Post pictures when you've done! I suggest to use the EKwb Vardar EVO instead of the Chromax 140mm. At the same speed, on a heatsink they are more efficient and silent. I never liked the sounds of the Noctua A14.Yea. I know the numbers, but I suspected it could fit, albeit tightly. I had to slightly bend one of the pipes top, but it did fit. Down to a milimeter.
Oh, man... I am so sorry. Noctua NH C14S already arrived I spent my day figuring how to fit it best. @fabio is totaly on point. There is no clean way to fit C14S into this case. Ended up turnin cooler so that modded GPU is on top (intake) and cooler's top protrudes bottom double dust mesh, which had to be removed as well.
Oh and... Rear 92mm fan from that build was intake, FUMA mid cooler same direction. Keen eye, sir - had it reversed for testing. Wrong setup is +15 degrees Celsius.
Learned 2 interesting things yesterday.
As I tore the build apart I took time and also modded my MSI 1080ti Gaming X. Removed factory cooling (one of blades broke as card is 2.5 slots wide and the blade hit the fatter acrylic sheet adn broke off), replaced with 2 Noctua NF-F12 PWM chromax. Hardest part was modifing standard 4pin PWM connector to fit GPU onboard connector. But happy to report GPU runs cooler and more silent. Also fans stop as originaly designed.
Also when trying different orientations for C14S I realized that inner power extension cord can be pulled apart if needed.
No pictures of this second version of black/red as I am waiting for 140mm cromax Noctua.
But will do Aida64 stress test and post results today.
Never heard of that company before, only to learn now that this premium brand is from my country. An hour drive from my home.I suggest to use the EKwb Vardar EVO instead...
Any thoughts on reducing GPU temperature in my case? The RTX 2060 Founders Edition is getting really hot during load (82c max). It blows all the hot air to the right side of the case and the right panel starts to get very hot. I have no intention of overclocking, and I only want to use fans (no elaborate setups).
(above) That's a 140mm Noctua Redux. Right now I'm thinking of adding a second one next to it. I can't slide it all the way to the left because it then bumps against the 92mm Redux facing rear. The 92mm could be moved though. I took off that magnet mesh panel because I'm pretty sure it just blocks too much airflow.
(above) An inside view of the gap between the 140mm fan and the RTX 2060 FE. It seems to fit without touching.
(above) All that hot air from the GPU blows straight onto the motherboard, cooking my 2x M.2 drivesThe case panel on this side gets alarmingly hot, probably because it's pure aluminum.
Actually, the SSDs, CPU and motherboard all seem to have tolerable temperatures (unless someone suggests otherwise?), my main concern is the GPU.
I could look into mounting the 92mm Redux below the PSU here as an exhaust. The 92mm fan is currently an exhaust on the rear of the case, but I honestly doubt it's having much of an effect there because all the heat seems to be driven to the right-hand side.
Also, as someone suggested in this thread, I could slide the PSU back towards the opposite side panel. That would give more room for a fan on this side. Or possibly just more breathing room.
Max temperatures:
From my brief observations, the average GPU temp under load is around high 70s (celcius).
Looking forward to hear the results!
Hey man! Just to show you the U9s with 2 A9 PMW fans, flow left to right, all core 5ghz, with AVX offset of 3 (Working in AIDA at 4.7, then), Undervolt of -20mV one 140mm fan exhausting on the side.Although my heatsink has three broken heatpipes, I have done several tests with it and clearly the best airflow configuration with this box is from left to right. Tests with Aida64 and no power limits (9900K all cores 4.7 GHz). With the heatsink in good condition I'm sure that the temperatures could have been lower... how much? I don't know, maybe 10º less?
I’ll try the SW 130 this evening and I will let you know!Yeah, that looks like a good temperature. Surely I should have stopped experimenting and gone for a U9s, but the damage is done.
Thanks man
The interesting thing is that the right-hand side panel (which bears the brunt of all that GPU heat), is a lot cooler to touch now that I installed that second 140mm fan. Previously the panel would get extremely hot. The fan made a big difference to the side panel, but not the actual components.
So basically an open bench, good work on your side, Streacom..... not so much.Stardate uknown. Log entry 20145. DA2 build epilogue.
My Streacom DA2 black/red build with Scythe Fuma Rev.B eventualy became Streacom DA2 black/red build with Noctua NH-C14S.
As GPU has is modded with Noctua fans (better cooling and noise management) and Noctua is a hard fit for Streacom DA2, both upper and lower dust filters and plastic covers had to be removed.
MB/CPU hover arround 34/35 degrees when idle and don't go over 69 Celsius when gaming. When sides with dush mesh are on, temps on load are 75ish. Content. Case closed.![]()
So 69C under load is without the side panels or with side panels and no mesh?Stardate uknown. Log entry 20145. DA2 build epilogue.
Yes, those are the fans that I set to hit 90% and higher once the motherboard gets to around 39c+. They speed up as soon as I start playing a game.What speeds are those 140mm fans running at? Have you any manual control over them - can you set them to run at 100% all the time? What does that do for temperatures?
I would flip the mounting bracket so that the 140mm intake sits above the GPU and acts as an intake for the CPU only.
Noted!I suggest moving the fan up, say, 30mm to clear the exhaust air path from the card's top edge. Let the card's exhaust air comes out more easily and then be drawn away by the air flow above it.
Interesting point. I also wonder if part of the problem is because these 140mm fans are not secured to the side panels. So the gap between the fan and the panel is killing its effectiveness.b. On the right side panel, the 140mm case fan is exhausting. ... I suspect your NF-P14r does not have enough static pressure to push air through the restrictive holes of the side panel. I suggest trying with a fan with higher static pressure.
Now this is surprising. I have not overclocked this card. I wonder if they're designed to have short bursts of overclocking? Note that in the screenshot, it shows the maximum MHz reached. I don't know how long the card was running at that speed. I wonder if it was just a temporary spike.c. Stock boost clock of a 2060 FE is 1680 MHz but you have 1920MHz, indicating the card is having a hefty overclock. A non overclocked 2060 FE should have a stressed temp of about 69-70C. So, 82C might just simply reflect the overclocking?
