Update 2nd June 2017 : (Almost) Completed Build!
Here is a MAJOR update of my KI Cerberus-X build.
Indeed, from last update I've received several "COOL" parts, and I must admit that my build is almost completed!
Ready to go?! So let's go!
- KI AC Extension : I received official KI AC extension (I guess I'm one of the first user..
). This AC extension has proper length (to face all psu plug orientation), good flexibilty, good quality overall. Assembly it on Cerberus-X is exactly the same as my Node 202 : 2 screws (same as side bracket) and it's done!
This AC extension allows me to close my top panel, at last!
- KI RED TOP PANEL : As you may remember, I've received, by mistake, a top black panel instead of top red panel. KI sent me a RED top panel. As I can now close my top panel, it's a matter of taste...which top panel do you prefer? BLACK or RED?
- Revised Fan setup & Dust Filters : After several trials I discovered that Corsair SF600 psu (like SF450) noise is depending mainly on its ambiant temperature. SF600 fan speed is mainly following temperature, so it's mandatory to keep SF600 as cool as possible.
Following this analysis I revised totally my fan setup. Indeed main priority is to push all hot air coming from GPU to the back of the case. Thus I placed a 140mm intake on front panel just below psu, and in front of GPU. thanks to Corsair Commander Mini+SIV I've linked this 140mm fan speed to GPU temperature.
I've also kept a 140mm fan on bottom to cool air at back of the case.
At last I've plugged rear 92mm fan to Commander Mini (to avoid unnecessary high speed due to MB control)
In addtion I've added dust filters on bottom and front fans.
- I've tried to put some dust filter on Noctua C14S :
HOWEVER, as side brack is empty in the middle, dust filter (as mine is soft) was suck by fan...and finally dust filter was touching fan motor...
Also I cannot put a 140mm magnetic fan filter due to border of side bracket. So I will need to find a rigid, slim 140mm dust filter..or leave it like that.
Globally here is the result of the full setup :
I guess that's all for the change except if I forgot to mention a BIG change by purpose..
For you, reader that managed to reach this part of my log, I will have 2 questions for you :
- Do I forgot to mention a big change in my setup?
- Do you prefer RED or BLACK top panel?
Thank you for your support and feedback!
Also I would to present special thanks to :
Long live Cerberus & Cerberus-X!
Enjoy!
