With the HDPlex 160 (and only that, with an internal 160 Watt Brick), you have a power budget of 160 Watts max. The GTX 1060 is very good about remaining at its TDP (120 Watts) in terms of power consumption. 120+65(TDP of your Intel chip, which is generally also about how much it consumes) = 185watts consumed before peripherals like memory, storage, and cooling fans.
Unless you can shave off a fairly significant amount of power draw from your system (which has been done! I don't mean to discourage you!) you'll be really pushing the limits of what the power delivery system can handle here. It can take ~ 200 watt spikes; you shouldn't ride that line constantly.
-edit-
Also, TDP and power draw with Coffeelake seems to vary pretty significantly based on core count, even within the same suggested TDP range (ie 65 watts or 95 watts)
-edit-
