Wow.How about a poster!
YesWow.
Is that your build? Any links so I can see more?
Beautiful. ANd I think the side panel put is perfect. I can't wait to see the final water loop build come together.How about a poster!
man this is like what the 90s people imagine what computers might look like in the futureHow about a poster!
Quick question: i7-8700 or a i7-8700k for a brick less build? Would an undervolted, delided 8700k run the same or cooler than a 8700?
I'm using a 1050ti btw and am using the HDPlex 400 with a noctua fan low profile for cooling.
Going brickless with an HDPlex 400? Would you even be able to take advantage of that? I thought only the 200W brick fit in the S4M.
But will it fit a zotac 1080 mini? If not, I'll pass.HDPLEX is supposedly working on a new 400w AC/DC that will fit into the S4M.
As planned, will fit with a Gigabyte 1080 Mini (front of case) or a reference height GPU (bottom of case). Unfortunately the Zotac 1080 is oversized with respect to height (125mm vs. 111.15mm) and length (211mm vs 170mm), and will likely not work without some form of modification.
Have anybody come across this build below?
https://uk.pcpartpicker.com/b/nLpG3C
I believe it should be from one of the members.
Can he throw the light on building a brickless with a 1060?
Hello, I know I have to buy this specific power brick from dell for my s4 build.
Dell: http://www.dell.com/en-us/shop/dell...h-6-ft-power-cord/apd/332-1432/pc-accessories
I got this instead, will this brick work?
https://photos.app.******/PA2463MGFX6J9wUC3
Can any1 please help confirm for me. thanks
