Nothing too fancy, I'm waiting for this oneSent my side panels for powder coating today *squeeeeee*
Also...
Just gonna leave this here
Look at this beauty![]()
sweet build! you really put effort into it and on lowering thermals!Everything has arrived and there is snow outside in London, so might as well stay indoors and build...
Intel i7 8700K
Asus ROG Strix Z370-i Gaming
Team - Dark Pro 16GB DDR4-3200 RAM
Thermolab LP53 w/ Noctua NF-A9x14
2x 512GB Samsung 960 Pro
Zotac 1080 Mini
HDPLEX 400W HiFi DC-ATX PSU w/ Dell 330W AC-DC PSU
Skywire cables
Initially had the Noctua NH-L9i, the Thermolab turned up this morning, so i swapped it for that instead.
The weekend was spent trying to get power and thermals under control. At stock bios settings, the motherboard would send silly amounts of voltage to the CPU (1.42V) and RAM (1.53V). And with those I was hitting both thermal and power limits.
Using Ceski's guide that CubanLegend posted a couple of pages back (https://smallformfactor.net/forum/threads/s4-mini-classic-s4m-c.96/page-209#post-68547), and with some trial and error I am now at
CPU offset = 0.6V
LLC = 6
Speedstep = enabled
with other settings the same as in the post linked above. Not ideal because power is still the limiting factor, I hit 99-100W, with the limit set at 95W by default. Now i can raise the limit in the bios, but I would rather try and reduce power consumption first.
CPU temperatures maxed out at 68C. The CPU has been delidded with Thermal Grizzly Conductonaut between the die and IHS and Thermal Grizzly Kryonaut between the IHS and heatsink.
Next steps for me -
get the RAM running at 4000 MHz with the undervolted CPU.
follow CubanLegend's guide to reduce the 1080 mini's fan speed.
setup and test RAID 0 on the SSDs
Thanks to all on this forum. A huge amount of reading but this has been one of the easiest systems to configure and build in.
If you use the included skybracket duo, you won't have to zip tie any other fans on.[...]I think I might remove those fans and cable tie some noctuas on instead, I find the stock fans jarring.
Intel i7 8700K
Zotac 1080 Mini
Skywire cables
CPU offset = -0.6V
LLC = 6
Speedstep = enabled
Next steps for me -
I just finished trying this out myself just half an hour ago. Sorry if all this is already common knowledge but I can tell you that using the skybracket instead of cable ties means that it's a pretty tight fit to slot the GPU in, mainly just getting that DVI port through the i/o slot. But it does fit with a little bit of persuading.Thanks! I'd forgotten about that bracket. I'd taken it out. Fans are coming on Thursday, so I'll have a go at it then.
A little quirk with doing it this way it is that the fans don't sit perfectly central over the heatsink so I found my temps actually went up a couple degrees compared to stock but the Noctua fans are definitely quieter.
You'll notice that you can mount the skybracket at 2 points over the GPU and having tried the fans in both places it seems that using the ones nearest the motherboard were keeping my fans slower by roughly 70-100rpm. However I'll end up cable tying them to the heat pipes or drilling new holes in between the 2 existing mounting points just to satisfy my inner perfectionist.
Hardware I used was the Zotac 1080 Mini, 2x Noctua NF-A9x14 PWM with a gpu fan adapter and y-splitter (sadly I never got a hold of the 2500rpm fans). I just used Unigine Heaven to gather some rough numbers and my trusty ears to determine noise, nothing scientific.
Hope this helped!
Holy smokes 68C at max? Like even at 100% utilization?
NFC Machined On/Off switch, proven and tested so fits perfectlyWhat button did you order? It fits so well with the carbon fiber!
Intel i7 8700K
Zotac 1080 Mini
Skywire cables
CPU offset = -0.6V
LLC = 6
Speedstep = enabled
Next steps for me -
Intel i7 8700K
Zotac 1080 Mini
Skywire cables
CPU offset = -0.6V
LLC = 6
Speedstep = enabled
Next steps for me -
wow, i need to get my room to 20c and re-run that P95 26.6 bench to see why my 7700k gets.Yep, at full load. 20C ambient temperature. Ceski did even better, getting 63C at 26C ambient. Both running prime95 26.6
hmmm, ive got 2 of the 2500 RPM fans form Noctua and the gpu can adapter and the y splitter...why didnt you just plug them into the motherboard and control them independently using the GPU temp as a curve? What was your fan curve for the Noctuas hooked up to the 1080 mini? what was your lowest RPM and was it quieter and cooler than using the stock fans?I just finished trying this out myself just half an hour ago. Sorry if all this is already common knowledge but I can tell you that using the skybracket instead of cable ties means that it's a pretty tight fit to slot the GPU in, mainly just getting that DVI port through the i/o slot. But it does fit with a little bit of persuading.
Hope this helped!
I didn't control them independently from the motherboard because I never knew how to be honest! Would there be a benefit to doing it this way? I get the feeling my afterburner software is lying to me a bit (maybe because I'm using the GPU fan header?).hmmm, ive got 2 of the 2500 RPM fans form Noctua and the gpu can adapter and the y splitter...why didnt you just plug them into the motherboard and control them independently using the GPU temp as a curve? What was your fan curve for the Noctuas hooked up to the 1080 mini? what was your lowest RPM and was it quieter and cooler than using the stock fans?
This is amazing. Would you mind posting (sharing) your exact bios settings? I have almost the same specs as you aside from the 960 Pros. I have a single 512GB 950 Pro.
Also, in Image 2/3, I cannot see the copper heatpipe's bent ends and the pointy ends. Where are they? They aren't making contact with the RAM like in CubanLegends flicker images.
How did you figure out to use LLC 6? What guide did you use or method to figure it out? What effect did that have on the CPU?
wow, i need to get my room to 20c and re-run that P95 26.6 bench to see why my 7700k gets.![]()
I picked up an i7-8700K and a Strix Z370-I and ran some thermal tests in an S4 Mini. Here's what you can expect to see with two of the more popular coolers, a Noctua NH-L9i and a Thermolab LP53 (using the Noctua fan):
Details:
Test Configs:
The CPU was stressed with Prime95 26.6 (no AVX) with 8K in-place FFTs. All testing was done in an S4 Mini. The following images show how the coolers were mounted:
BIOS/UEFI Settings:
The latest BIOS update is supposed to disable multicore enhancement by default but it still reverts to overclocking focused "Auto" settings once you enable XMP for your memory. As a result, the CPU will draw about 120W at 4.3GHz before power limiting and throttling to 95W at 3.9-4.0GHz. When properly tuned, the CPU power drops to 86-88W and maintains 4.3GHz under all-core load. The "Tuned" settings listed below simply force the processor back to stock behavior. The VCCIO/VCCSA voltages work fine for typical DDR4-3200 and can be adjusted for higher speed kits.
VRM Heatsinks:
Removing one or more of the VRM heatsinks improves airflow and reduces CPU temperature at the expense of warmer MOSFETs. Since no one will be overclocking much, or at all, in the S4 Mini, the MOSFETs should stay reasonably cool. You can buy some small heatsinks if you want more peace of mind. Here are some thermal images of the bare VRM under Prime95 load:
Delidding:
Just like the 7700K, delidding is helpful and pretty easy to do. I used the Rockit 88 kit and liquid metal. There's no tiny resistors to worry about on this chip.
Thermal Paste:
I used Noctua NT-H1 for every test except the last. Thermal Grizzly Kryonaut reduced core temperature by 2-3°C but there's nothing wrong with the stuff Noctua includes with their coolers and it's easier to apply.
Conclusion:
Managing the 8700K in the S4 Mini is a lot like the 7700K and 6700K before it. Expect to spend some time getting temperatures under control by delidding, tuning, or modding. My guess is that the i7-8700 will also be difficult to cool, despite the claimed 65W TDP. Strongly consider the i5-8400 or Ryzen 5 1600 for an easier time. For cooling, like @Josh | NFC has mentioned before, Noctua is still the best overall when considering mounting, compatibility, and price.
Update 2/27/2018
Got a new radiator today, time for some new tests
I undervolted my system and turned off Asus multicore enhancement, as well as some other tweaks.
Now on AIDA64 stability test, after about 10 minutes, the temperature stables at around 60°C!
