SKYREACH 4 MINI (S4M)
teisysadmin
26
@Josh | NFC I took some photos of the inside of my S4 and did a little test fit proving that, at the very least, it would be possible to reverse the PCIe slots in the S4M and mount a Zotac 1080mini / 1080ti mini in this alternate orientation without expanding the case. This may or may not hold for other GPUs.
I'm going to see what I can do about creating a model for the hypothetical alternate part because these pictures and drawings aren't great.
EDIT: Here's a link to an early sketchup model for the hypothetical reverse GPU chassis back / bottom. Since the sketchup model I was working off of doesn't appear to reflect the S4M 100% accurately, this isn't likely a viable model for a real part. Any chance there's a model of the S4M floating around the internet that is 100% reflective of the final S4M design? Either way, I'm going to convert this sketchup model to solidworks and get some quotes to have a one-off part manufactured.
This configuration would not be viable for brickless builds, GPUs with power connectors on the top of the card that are too close to the motherboard, or builds with sata drives. A small amount of space above the GPU would likely have to be sacrificed to ensure there is enough room for the PCIe riser cable underneath the GPU, but the configuration should still allow for full thickness fans to be placed on the GPU heatsink.
Waiting for my parts to get in on Monday so I can do some benchmarks to show why / if anyone should care about the possibility of mounting their GPU "upside down."
SECOND EDIT: Riser cable and A9s showed up today. Riser cable was a bust, will need to try a different cable. A9s seem to be a marked improvement over the A9x14s, but I didn't do any proper benchmarks with the A9x14 without the side panel on, so it's hard to say exactly how much of an improvement the A9s made, versus how much of an improvement pulling the side panel off the case made. Seemed to be about a 7C improvement at least, but the card was maxing out around its thermal limit with the A9x14, so the difference might have even been a little bigger, had I been running the card in its purely stock configuration.
Heard back from one sheet metal fabricator, who said that they cannot make the part using their conventional press brakes. Anyone have recommendation for good shops that I might want to reach out to who might be able to manufacture this part?
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
@Josh | NFC
I had to buy tooling at LIAN LI to make that piece.
Everything about this thumbnail is amazing (busted feed, video games, no S4M). Keep up the good work @Josh | NFC . XD
I had a slight motorcycle accident so no stream today. I'm fine just some bruises and a concussion. Bike needs repairs. My guardian angel was on full alert.
teisysadmin
26
Wishing you a quick recovery.
Just got a quote for the part. Number was a little higher than I had hoped, but there are a few places I can shave the cost down for the purposes of a one off mod for my very specific use case.
Any chance you'd be willing to share a .sldprt file or similar with me on the conditions that:
  • I do not disseminate the file to anyone other than the manufacture who will produce the component.
  • Have no more than one part created.
  • Agree that the modified model is not to be published anywhere.
  • Will not hold NFC liable in any way from issues arising from the installation of an unapproved component.
  • Forfeit any warranty that I may have on the S4M.
  • Acknowledge that the modification I intend to do is not recommended, will restrict my options with regards to expansions / addons for the S4M, and acknowledge that the modification in question may have a domino effect.
Reactions: Soul_Est
Josh | NFC
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
Just send me an email bro.
Nightblade
284
235
I think this looks great! Especially if the ports do not stick out when unplugged :)
The ports don't stick out when unplugged, but the USB ports are really close to the 6 pin for my graphics card. I may move them back a little if it becomes problematic.
Reactions: Nanook
SushiOne1
Hello,
Does anyone know the exact power switch panel cutout diameter? I found a 16.2 mm switch and was wondering if it will fit the S4M?
Thanks
