Hey guys!
I want to share with you my idea. Maybe here it will be interesting to someone.
A little background.
I started to monitor different startups, starting with N-CASE, then DAN CASES a4-sfx, NFC S4 MINI, DR ZABER CENTRY. These are very cool projects and they are unique each in its own way. But they all did not suit me for one reason or another. They were not available to me. All of these enclosures have one problem. They can not be placed close to the wall because either the wires interfere or the ventilation holes are closed. One case is very large, the other is very small. I realized that I needed a tower-type hull.
And then I accidentally found the KSliger DSE Breathe case. I was just in awe of him. BUT it is not on sale. And I decided that I would try to make a case that meets all my requirements.
The main requirements for the case:
1. The case should be as small as possible, and not just small, but should occupy a minimum of space on the table.
2. The computer in this case should be powerful.
3. The computer in this case should be quiet.
4. Ability to install two and three slot video cards.
5. Ability to install a cooler for the processor more than noctua nh-l9i.
6. Install the standard sfx power supply.
7. Ability to install the housing close to the wall.
8. All wires must be hidden or neatly folded.
9. Theoretical ability to install water cooling. 1 x 120mm radiator.
10. Install at least one 2.5 inch ssd.
At the moment I have the following components:
1. asus maximus vi impact
2. intel i-7 4770k
3. Scythe Big Shuriken 2 Rev.B
4. ram G.skill 16g
5. corsair sf 600
6. ssd m.2, hdd 2,5
7. zotac 1080ti mini
Zotac 1080ti mini is an excellent video card, but very noisy. Even in idle time, the fans created a perceptible noise. I decided to remove the factory fans and change them to 2x 120mm fans be quiet silent wings 3 120mm pwm. And about the miracle the temperature dropped from 84 to 67C while they were much quieter.
Ok, now I had to somehow put it all in order to understand how it would look and how it would work. I made it very simple. I took an aluminum corner, bent it and attached it to a wooden board. It looks like this:
Then I began to draw in the sketchup my future prototype. I decided that the case would be made of metal with a thickness of 1 mm. Looking ahead to say that I will not talk about how much time I spent on it and how many models I redraw. At the design stage, I had a lot of questions: how much space is needed for the processor's radiator, and how much is needed for the video card. And if I change the video card tomorrow, for example, the 3-slot asus strix? And if I want to swap the video card with the motherboard. Today I like when the case is to the left of the monitor, and tomorrow I want it to be on the right. But I still want to look at it, for example, on a video card. How do I do this? I thought. And every time I redraw and redraw. And here I had an idea that I had never seen anywhere else: why not make it so that the video card and the motherboard could be moved inside the case? After all, I need quite a bit, only 30-40mm. And so that you can swap them.
So I came to the final version. Below you can look at the pictures. What do you think about it?
UPDATE. I posted all the photos on the google drive, because there are problems with viewing.
link to google drive:
https://drive.google.com/drive/folders/1K3SJK4xSVWQ0ciiFOjjN0LqAQOjNxkLs?usp=sharing
2. intel i-7 4770k
4. ram G.skill 16g
5. corsair sf 600
6. ssd m.2, hdd 2,5
