My stand I'm not ready to display yet, but it is for the horizontal orientation not the vertical. The S4 MINI was designed to stand securely on its own vertically so I haven't come up with a stand yet for it.
I thought that was the length of the Zotac 1070 mini. According to the source on Anandtech, the 1080 mini is based off a design and will be about 6.7". Should fit fine assuming that its not too tall.1080 mod time to fit in s4 mini 8.2" .2" to long but josh called a mini 1080 would be nice
Hope the length is right. Doesn't seem like there's any way to shave off extra length short of cutting down the heat sink itself.Doesn't look tall. Very little of the board is above the bracket which is standard height. If they keep the board to 170mm I'll be amazed. I'm glad at least one of the manufacturers took a crack at this.
Still, it will only fit if the shroud was removed. kinda sad..It looks like the 1080 will have a shorter height than the 1070 did.
https://smallformfactor.net/news/zotac-geforce-gtx-1080-mini
That's what I'm going to do, the only thing I'm missing now is the miniHas anyone been able to fit the current ZOTAC GTX1070-mini into an S4 mini? Wouldn't it give us a good idea regarding fitment of the 1080-mini?
The cooling system seems to be a little longer than the one used on the ZOTAC GeForce GTX 1070 Mini, but the whole graphics adapter is barely longer than 17 cm (6.7”) specified by the Mini-ITX spec.
Just re-read the article. Thats unfortunateI believe the Anandtech article was just saying that the card would be a little longer than the 6.7" mITX spec.
From the article:
Hello, Fabien, and welcome to the forum!
The Zotac 1080 is a little long without mods, and inside the Node 202 or S4 MINI it is going to be quite hot, though if you do the bezel mod on the MINI you have the best chance of cooling it.
Peace!
The S4 mini has a solid brushed aluminum finish bezel which covers the front of the case, the top and part of the back. Removing the bezel allows for better airflow to certain parts of the case. Others have attempted 1060 builds without removing the bezel and the temperatures seem fine.What is the bezel mod? I've got an HDPLEX 250w on order, S4 Mini on order (was in this past Nov. preorder), and a Dell 330W brick already delivered.. so I'm currently shopping GPU's. I was thinking of going with the GTX 1060... would you recommend the bezel mod for a GTX 1060 build? Not certain on CPU's yet. Since it's so close to Ryzen, I'm probably going to wait and see what all SKU's are available there (hoping details are announced at CES). Otherwise it'll likely be a reasonably high end i5 or i7 non-K part.
Thanks
Just re-read the article. Thats unfortunateHopefully its below 8"
