Batches of this will continue to be made, but less often than before IIRC. Sorry about that :/Where can i get this case? The new s4 mini is not for me![]()
I don't believe there's been any announcements unfortunately. Perhaps by the holidays? That's when the last one was.Do we know when the next batch will happen? I just discovered sff builds, and an hoping to throw together a Ryzen 2/vega 56 or GTX 1070 build soon. The S4 mini Classic looks like the chassis for me, especially with the Sky skins .
ofcourse, if you can do it without breaking it, youll gain 5-15°C lower tempsExperiencing CPU temps of around 85 degrees while gaming which i believe is quite high. Currently using a i7 7700 (non K) coupled with the noctua L9-i cooler. Is it worth deliding the CPU to get temps down a bit? Any other advice to get CPU temps down?
Need to know your clock speed and if you delidded or not.Is it normal to see average temps of 85 degrees while gaming for an i7 7700(non k) in a S4 mini classic?
Surely I’m doing something wrong here seeing temps this high while gaming as it causing some games to stutter. If anyone can tell me what temps they get while gaming, that’ll much appreciated as my last resort is deliding the CPU!
Also last question what CPU and cooler setup runs best inside the S4 mini classic, I know this is down to personal opinion but it would be great to get some advice on this as I don’t fancy hitting the high 80s while gaming!
Just to mention I am running the rig on a ASUS PG348q 3440 x1440p monitor, could this be why my cpu runs so hot?
My current setup:
I7 7700 (non k) cpu
Noctua l9-i cpu cooler
Hyper x ddr4 2666 ram 16gb
Asus Z270i motherboard
Msi Aero 1070 itx gpu
HDPlEX 400
Dell 300w Power brick (purchased direct from dell)
Well, granted you can't overclock it so you might have a bad TIM application for your heatsink. I'd try reseating that. Otherwise, seems that the Kaby Lake chips run hot. Also, see if multicore enhancement is on in your bios. Turning it off should lower temps.Hi,
I’m not sure what the clock speed is as I’m currently not with my mini, I haven’t delided the CPU!
It is a good one, but he meant it could be applied badly. If you have time to take it apart, see if the thermal paste spreaded properly. If it is, then delid is your next option.The thermal paste i used was the one that came with the noctua l9-i, surely that's a fairly good thermal paste? Would you advise deliding the CPU in that case? Will have a look at multi core enhancement now and see if that makes any difference, thanks for your help!
Just taken it apart as I plan on deliding it as I don’t think there is another option, I applied a pea size amount (did I need to spread it across the CPU?) because I didn’t but it all looks good.It is a good one, but he meant it could be applied badly. If you have time to take it apart, see if the thermal paste spreaded properly. If it is, then delid is your next option.
Should spread out nicely on its own. Just sanity check that you removed the plastic protection from the bottom of the heatsink if it's still accessible. Then I'd still double check multicore enhancement.Just taken it apart as I plan on deliding it as I don’t think there is another option, I applied a pea size amount (did I need to spread it across the CPU?) because I didn’t but it all looks good.
Yeah, heatsinks tend to have a plastic film on the bottom, to protect the surface until it's ready to mount, though I'm not sure about yours. Every now and then it gets overlooked and significantly increases temperatures.Plastic protection from the bottom of the heat sink? Checked multicore advancement and some games like battlefield, performance is dramatically decreased so turned it back on although temps did drop slightly
Sounds like a prime candidate for an undervolt unless you've already done that? Even -50mV offset might be enough as doesn't seem like you need to drop a lot.Is it normal to see average temps of 85 degrees while gaming for an i7 7700(non k) in a S4 mini classic?
