S4#25
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
What is important is if the fan will continue to operate silently with the side panel on. I am pleased to report, it does. That's all for today!
:thumb:
Reactions: Soul_Est and Phuncz
jtd871
1,166
848
Could you not remove the fan brackets while leaving the fins? The fins appear to be structurally independent of the fan mounting.
It's a huge indictment of the shroud design, however. D'ya suppose marketing had something to do with that? ;)
Reactions: Josh | NFC
Josh | NFC
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
I tried, but they were physically pressed together--the brace holds the fin assembly together for whatever reason. The good news is that the card can be put back together 100% with no one the wiser, in case the card ever has to go back for repairs, or the customer wants to sell it.
Janaka
Well I guess that solved the issue of the card being a fraction too long for the case... Remove the shroud and cool with a fan nearly the size of the card! Monumental work Josh! Loving the photo journal :D
5,570
4,778
Very nicely done, especially the photos are nice to follow the progress you made. I have a 100mm Scythe slim fan and it's absolutely silent at 100% and after running for years 24/7, the bearing still works flawlessly. Amazing fans these are.
michaelmitchell
117
73
How tight was the fan fit width wise? Would a 15mm thick fan fit or do you think it would be limited to 12mm? This is the only GTX970 available to me at the moment and I cannot get my hands on 120x12mm.
Josh | NFC
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
Assuming you mean this exact Zotac card, I filed the shroud mounts so that they were flush with the fan (for the titest fit possible). If you want to fit a 15mm thick fan just file them down a bit more. Just fully test your GPU before doing this in case you want to return it...
I f***ing love the vintage look of your pics. That's so gorgeous !
Why, thank you!
TheInternal
53
Your photoset rocked. As a nerd with two degrees in media production / that taught videography a bit, I'd have to say you successfully did photography. Kudos. What camera did you shoot with / do anything special for your lighting?
Josh | NFC
NFC Systems
Jun 12, 2015
1,869
4,464
www.nfc-systems.com
Sorry I missed this. I think I shot them with a A7ii. Fuji is my favorite system but I use the Sonys for video. As you hint at though it's all in the lighting. Off camera strobe + speed light for most of them with some 98CRI LEDs for contrast.
*edit*
Thanks for the compliments, btw...I don't deserve them for this but I do appreciate it!
489
1,068
I am browsing the web today, and I found this, the Nidec 4010 U40X12MLZ7-52, a 40x40x10mm fan: link
Then I realise this will be a perfect addition to the 120mm fan, we can use 3 of these on each side of, which makes up to a total of 200mm :D
