Log Riba's 14L N-ATX water-cooled build - 3700x + Vega64
thelaughingman
1,410
1,564
@riba2233 just a quick question, can I still mount the 360 radiator at the bottom if I use the Crosshair VIII Impact (mDTX)? Or that is only possible with ITX motherboard?
thelaughingman
1,410
1,564
Unfortunately no, it not even close.
because the motherboard mount is too low right? i.e the empty space up top for fan mount and to clear the power cable extension?
theoretically the inner case height is 348mm > 203mm (mDTX) + 133mm (GTS 360). so let's say if I do some modding to move the power cable mounting outwards, then tap in motherboard standoffs in higher position that would work?
riba2233
2,003
2,612
Croatia, EU
www.sfftime.com
Sure, with some amount of modding it would fit, there is enough space.
Reactions: thelaughingman
Retrias
157
77
I use that specific motherboard , and I can tell you there is no space for it on the bottom , the additional sound card space takes out so much of the needed space
thelaughingman
1,410
1,564
yeah I use the same board, thus my plan to do modding on the case. where there's a will, there's a way 😌
thelaughingman
1,410
1,564
Goodluck ! , I will be going to another route by changing my mobo to ATX, unless next gen ITX have 3 slot m.2
thanks! I cannot use ATX because I need to fit a 360 radiator at the bottom haha aircooling the 5950X with top-down cooler is a non-starter for me
thelaughingman
1,410
1,564
Here you go, I made some renders with 60mm 360 alphacool rad model that I have:
hey, just want to double check on this render - the clearance of 30.58mm from the top of the motherboard to the top of the case, in this case the motherboard is mounted on:
  1. standard mounting position? OR
  2. the optional mounting position (that is 5mm higher) per page 9 of the manual?
Been looking at the manual today and I think the mod will be fairly simple - drill 3 more holes for higher motherboard standoff (2x top mount and 1x bottom left mount), cut out for the new cable plug hole and cutting the bit of the case to enlarge the rear IO cutout
riba2233
2,003
2,612
Croatia, EU
www.sfftime.com
Hey, yeah it is from the top of the motherboard to the top of the case in the standard position. Optional puts it 5mm higher, closer to the top panel. And yeah, you are right, that is all it would take! You can use a grommet for the ac cable.
  • Love
thelaughingman
1,410
1,564
@riba2233 what bracket did you use to mount the pump by the way? Would be great if you can share some pictures of the mount.
I'm thinking since I'm using a D5 it will have to be a custom bracket or I'll have to butcher something.
riba2233
2,003
2,612
Croatia, EU
www.sfftime.com
I used the most simple 2-piece L-bracket that EK sells and screwed it in with 2 countersunk bolts and nuts, nothing special and it will probably be different for each pump and application.
thelaughingman
1,410
1,564
you mean these rights? EK-UNI Holder 50/70 Indeed they look to be very flexible and minimal.
I only have access to this Barrow bracket - luckily my D5 pump has mounting holes at both the bottom and the back so I think I can make it work. Just need to have the case in hand to measure out the holes to make sure.
thelaughingman
1,410
1,564
@riba2233 sorry for bugging you again with another question - the riser you're using is 20cm long right angle right? how much slack is left? and since I'm planning to move the motherboard up 30mm, would 20cm be long enough for the riser? Or should I look at 25cm instead?
riba2233
2,003
2,612
Croatia, EU
www.sfftime.com
Np, just ask :) There is a lot of slack, in normal configuration you have to make two bends, like in manual.
  • Love
thelaughingman
1,410
1,564
In my build the psu is actually 140mm. No, 160mm is the hard limit.
understood. I've recently got a 3090 FE so I'm considering PSU upgrades over the SF750, don't want the PSU to be tripped up during full load. Since 160mm is the hard limit, Silverstone ST1200-PTS seems to be the best option - 80+ platinum, 1200W and just 140mm in length
EDIT: Upon looking at the reviews, the ST1200-PTS got poor performance results, guess I'll stick to the SX1000 instead
