Hello all, I'm considering moving my current build to a custom SFF case and was doing a little research on a compatible PSU. I've seen a few people saying that the HDPLEX 160W DC-ATX PSU with the HDPLEX 160W AC-DC power brick worked fine for them with similar configs. In my current system I have the i5 clocked at 4.5Ghz as well as a +150Mhz offset on the GPU core and +300Mhz on the GPU memory. I'm okay with tuning these down a little, as long as I can reach maybe 4.2Ghz on the CPU and +100Mhz on the GPU that'd be fine with me. The only other things being powered would be the CPU and GPU fans, and a single M.2 drive. If I have to stay near stock speeds with the 160W then I'd definitely want something higher powered; any suggestions on this?
