Hey Alfredo, good to see you on the forums.
Gizmodo Australia reported the size incorrectly in their article. Please note that the size will change once again in V2 to accomodate AIO liquid coolers.
You cannot fit an SLI-HB bridge, but you can use 2 x Flex Bridges, which will provide very similar results:
The vents on the side panels will most likely change before the final product is released to accomodate users who want to use graphics cards with 3 fans. However I do think the best performance will be with blower style GPU's or with top GPU water-cooled.
I will try to test thermals with fan based cards, however I might need to community's help to get my hands on such cards.
Size has not increased to accomodate a 2nd GPU water-cooled. Only 1 GPU water-cooled will be supported.
Perfect about the sli cable, i didn't know it.
About liquid cooler instead, i see many confuguration with 2 vga 1080 in matx closer than yours and without a gpu liquid cooled, that works good, are you sure that this cooler is essential?
When we can see the v2 case?
Thanks for all
