Hey AibohphobiaConstruction is 2mm aluminum for the frame
Maybe a bit a stupid question: How do you hold two sheetmetal parts together? I.e. the frame, is 2mm enough thread for a screw to securely attach them together?
Can you please post more pictures![]()
Kudos to you @Aibohphobia ! The case looks great!
And here's a 5x spedup timelapse of the CAD modeling process:
Very awesome! How's the thermals? Is that a flex atx psu in the front?
Is this the 3D modelling software you enjoy the best when designing cases? Or how did you end up with it? I assume it costs a fortune as well.
Thoughts towards pulling the shroud & fans from the LP GPU & fitting dual Noctua NF-A9s (the "full-size" 25mm thick ones) below getting their PWM feed from the GPU itself…?
Right, I removed the stock fans on the MSI GTX 1050 Ti LP and plugged the two Noctua into the motherboard.
At top there's only room for slim fans.
So do you think that you will have a run of these bad boys to sell or just working on a custom box for your on the go rig? The LP gpu doesn't bother me in the slightest and the extra cpu cooler clearance is nice for keeping noise down on less powerful procs even.
Also, I would totally buy the handle alone for my own cases!
Would it be possible to attach the fans to the GPU itself, thereby having the (bottom) fans controlled by same…?
This case really appeals to me because of the ability to have Intake & Exhaust fans in such a small chassis…!
There will 3 extra available in a few weeks. They take the same handle as Cerberus but I didn't order any with this run so I'll have to check if any spares are leftover from the Cerberus pre-production run.
Yes, though I'd recommend a GPU with a PWM header if possible for better control.
I don't really think having both intake and exhaust is that important on a case this small. With adequate intake the case will be positive pressure.
I've quit using exhaust fans on my various Cerberus configurations for that exact reason.
@Aibohphobia - I would be interested in getting one of these chassis, would you please PM me with additional info regarding same?
Interesting to see that you had a number made up at the same time; I know that one off costs are large and having a batch really helps.
