After tonnes of waiting, I finally gather most of the components required for my build This will be a work log recording what I'm working on currently (and what I have failed miserably).
Specs:
Specs:
- Intel i7 6700 CPU
- G.Skill TridentZ DDR4 8Gx2 3200 Mhz Memory
- Asus ROG Strix Z270i Motherboard
- Zotac 1070 mini GPU w/ Scythe KAZE-JYUNI Slip Stream Slim 120mm PWM fan
- Samsung 1TB 850 EVO x2 SSD
- Samsung 256G 960 EVO M.2 SSD
- Noctua NH-L9i Cooler w/ Noctua NF-B9 redux-1600 PWM fan
- G-Unique Slim 400w DC-ATX
- NFC-Systems S4 Mini
First of all, almost all the parts that gonna involved in this build:
The motherboard, Asus Strix Z270i. A sexy board that really will fit my build theme:
The logo have a rainbow reflection under the light
The Strix logo, you just gotta love the color scheme:
The black capacitors and power delivery units:
SupremeFX audio unit:
I/O:
My CPU, an intel delided i7 7700K with a full copper heat spreader:
G-Skill TridentZ 3200 Mhz. Man the color!
Moving on to system storage, my boot drive, Samsung 960 EVO 256G:
Storage drives, two Samsung 850 EVO 1TB:
GPU, the Zotac 1070 mini. I bought this the day before they announced the 1080 mini sad..
Due to the length limitation, I have to remove the stock shroud and fans. In order to do so, I have to remove the whole heatsink first.
The heatsink, one of the reasons I choose Zotac instead of Gigabytes Mini 1070:
Now for the custom back plate I made for it!
Assemble them all back together:
GPU riser from Josh, I put some gaffers tape on it to give it the matte black look:
Moving on to the CPU cooler, I choose to use the Noctua Nh-L9i, the best performing low profile cooler on the market:
But wait! We gotta swap out the fans to fit our color scheme!
Looks muuuch better now!
I shorten the cable on the fan to make it fit nicely in the chassis
The PSU I'm using, G-Unique 400w Silm:
The golden G logo:
The 16mm power button:
Ah, you might remember we removed the fan on the GPU. For its cooling, we are using the Scythe KAZE-JYUNI Slim 120mm fan:
Modded the connector so I can directly plug it into the GPU:
Now starting to put things together, first, the motherboard assembly:
Now we have to take apart the S4 Mini to fit everything into it:
The cooling fan gotta go in first otherwise it will be a mess when we install the GPU:
Now the DC power jack, I'm using GX-16 here:
Time to put in the GPU:
Then the SSDs:
We are almost done! Next the motherboard:
Then.. tada!
I will continue to update the thread with more images. Remember the VFD screen in the start? It wasn't in yet
Thanks for watching!
I/O:
The golden G logo:
Then the SSDs:
Then.. tada!
