Stalled [New Video Assembly] Densium 4 & 4+ - Tiny cases with real hardwood frontpanel!
RedSawn
Speaking of the power button, forgot about this... the power switch looks a lot like the anti-vandal switches that can be custom sleeved and ordered from an SFF specialist I know, just more compact then I've seen before. But on the off chance that the Plus can fit a fatter button intended for one of these other cases, what diameter is the power button?
BrightNoah
Late to the party, just came across this lovely case. Hope it open for sales again soon.
Just curious, did you make the noctua colour cables for the plex PSU yourself or Overtek offer it? Can't find any colour option at Overtek website.
BrightNoah
Nothing crazy; Asus B450I, Ryzen 1600 w/ 16GB of 3200Mhz RAM, Noctua L9a, EVGA 3060ti, and recently bought the Velka variant of the Enhance 7660B w/ the shortened cables and blacked out aesthetic.
I also planning to use the NH-L9i for my next build (possibly in D4+)
you maybe interested to check out below video for adding fan duct to L9. It down 4.8C in a Dan A4-SFX case
Reactions: scatterforce
2,195
2,212
Norway
Here's a bit of an oddball question: what is the PSU clearance on the Plus? Is it 220mm, like the GPU? I have a MeanWell UHP-350-12 PSU in a current build that I'm hoping to keep through an upgrade (it's a great PSU!), but its 220mm length and end-mounted power connectors make it a poor fit for most of these ultra-small cases. I've been considering designing my own case, but this ticks most if not all of my boxes. I can get angled connectors for the power input and outputs, but will I be able to squeeze in the PSU?
Reactions: Densium.net
Densium.net
191
309
Yeah the PSU length support is roughly the same as GPU, though I think it would require some ingenuity to fit the AC input connector :)
Reactions: Valantar
2,195
2,212
Norway
The UHP-350-12 is very compact overall at 220*62*31mm - quite a bit smaller than FlexATX except for the length - and doesn't have an integrated AC inlet, so as long as the length fits I should be able to fit my existing external AC receptacle next to it in some way. I'm sure I (and my rotary tool) could make that work. I would love if you could check the exact internal clearance though (if you have any cases available to do so on obviously), as there isnt any wiggle room whatsoever in that dimension.
OJames21
Hello. I have tried to order a replacement part for my Densium 4 which arrived damaged. However, I cannot do this through the website. Can somebody assist me?
