There's an in-progress thread over on [H], but since quite a few people are more active on SFN these days I thought I would crosspost it here.
This is an idea we've been batting around for a while for a somewhat more portable, show-off friendly SFF case. I had done several iterations already when @wahaha360 took it upon himself to go ahead and try his hand at designing and CADing his own version of the case, and then getting a prototype made, since it's something he's personally interested in as he travels frequently. That prototype was partly to test some other manufacturing ideas, so it wasn't necessarily intended to lead to a final product. This version is my latest iteration that I've decided to show publicly to get some feedback as a possible commercial product for NCASE.
Similar to back-to-back designs like the DAN A4, the GPU is behind the motherboard, but facing the backside of the board, rather than the side of the case. The purpose of this is so instead of drawing air through the side panels, the components intake from inside the case, with fresh air provided by the two bottom-mounted 120mm intake fans. The GPU orientation also has the advantage of requiring a shorter PCIe riser compared to back-to-back designs. Downside is the face of the GPU is mostly obscured from view, for those who care about that.
I'm using a flexATX power supply in this version because it opens up quite a bit of space at the front, which could be used for 3.5" drives or pump/res/tubing in a watercooled setup. I'm not set on flexATX though, and its viability really depends on how some of the new units coming out perform in terms of their noise profile.
A top-mounted carrying handle is a potential option as well.
One of the major features of this design is the bottom section, which can be swapped out for an extended version that would allow for a bottom-mounted 240 rad:
Preliminary specs:
Overall, it's similar in size to the M1 - narrower, slightly deeper, but the same height (30mm taller for the W/C version). There are some trade offs though, mainly the quite limited CPU cooler height and PSU support. That's balanced by better GPU support, and more potential for show-off watercooling builds with the window.
Comments and suggestions are welcome.
Preliminary specs:
- Dimensions:
- Air-only version: 250 x 135 x 340mm, 11.5L
- Extended W/C version: 280 x 135 x 340mm, 12.9L
- CPU cooler: 40-45mm max height, plus clearance for air intake (~55mm max)
- GPU: dual slot, ~320mm max length, ~150mm max height
- Drives: 2x 3.5" or 2.5"
- PSU: FlexATX
- Fans: 2x 120mm intake
- Rad support: 240mm (w/extended lower section)
- Dust filters: standard on intakes
- Windowed side panel option
