NCASE M1 V6 info
Nescent
Hi guys, I am curious if I've missed the pre-order for the Ncase M1 v6?
Looking at the FAQ it says sometime in August, but notice the site says sold out for v6.
So unfortunately confused.
jack1940
65
Maybe producing additional components to support 240 mm AIO radiator in the future will be a more effective and realistic solution, just like ghost s1. It's only stronger than ghost s1.
SilverJS
244
117
Have the exact same question, came here hoping to find an answer...
Necere
NCASE
3,300
First round of preorders sold out in a few days, we've increased the size of the order and will open another round of preorders later this month.
Nescent
Thanks! Any chance you have a narrower window for when we should expect preorders to open up? I have a massive fomo for this case and gutted that I already missed the first wave by a few days, hate for that to happen again!
Necere
NCASE
3,300
Second half of August.
ps -ef
Not sure offhand what the height of the m.2 is. From the back of the motherboard to the right side panel is 11mm though.
Production is supposed to be done by mid September, I believe. So that's the earliest cases can ship.
Thanks for the info ?
Will avoid those with bigger heatsink, like Aorus nvme gen4 (H 11.4mm), on the back of the motherboard.
My guess the nvme slot need 1~1.5 mm from motherboard also.
SilverJS
244
117
I think this case is ever increasing in notoriety....I suppose that's good for you! :). I'll keep a lookout.
Ranker
85
What's the difference between the inside fan PSU configuration and outside fan PSU configuration. Is one more optimal than the other for temps? Are there any configuration issues to be aware of with either orientation? What's the purpose for being able to configure it in either orientation?
I'm about to order custom PSU cables and its an option I need to select.
2,719
2,854
I actually had mine with the fan facing away from the fan bracket, made it easier to route the 24 pin cable for me. Some people like to have the fan facing the fan bracket if they are using intake fans, that way the PSU gets fresh filtered air.
Reactions: Ranker
IanKen
Did some digging, and it appears the rear fan grate lost the 80mm holes which the Ice Man Reservoir/Pump uses to mount.
That seems to be the case...
I just finished doing a dual-rad (2 x 240) update using the xspc slim rads and the iceman res. I had to trim a lot of plastic off the front port connectors. I was hoping any revision would take into account the dual-rad scenario.
Nescent
What's going on here?
I checked this morning and the case was still out of stock.
I literally just got an email saying the case was in stock, So I rushed to purchase one.
Site says low stock, I get one in my cart and immediately it's out of stock...
How many where made available? 5?!?
So frustrated right now
Reactions: sffdeez
Ranker
85
I literally just purchased this. So the Ice Man res/pump won't be compatible anymore with the M1?
Necere
NCASE
3,300
same here. Got the mail at 7:22 AM, checked at 7:29 AM -> SOLD OUT
would love to hold one in my hands :)
Mate ... I got the email at 3:22pm Melbourne time. I have a screenshot showing it was sold out in my cart at 3:24pm
The notifications you're getting are from preorder cancellations that are opening one spot at a time. When the second round of preorders open, you'll have plenty of time to get an order in (days-weeks).
I've asked w360 to turn off notifications for now so you guys won't get frustrated by them any longer :p
Reactions: Fire
Necere
NCASE
3,300
Yeah, unfortunately I only became aware that res was using the 80mm mounting holes when it was already too late to make changes to V6. Sorry if that ruins anyone's plans.
