NCASE M1 V6 info
Mtrek
Feb 10, 2020
Yes, cases shipped starting in March will have the CE marking.
@Necere thanks a lot! That sounds awesome. I don’t know if you are aware of it but could reactivate the choice for those countries? At the moment there is no opportunity in the address section of my account to select Germany and maybe it wouldn’t be available when preorder starts.
Necere
3,300
We'll reopen Germany and the Netherlands when preorders for March open on February 22nd.
Will the sidepanels be available soon? Also, is the new transparent side panel compatible with the Ncase v5?
Side panels should be up sometime this month. The glass panel is only compatible with V6+.
Reactions: Twanvh
sunrainsky
35
I don't see the tempered glass panel on the accessories page. maybe it's just me.
I would like to ask about the top panel with ODD slot. When will that be available for order?
I do kinda wish that I had the option right at the start to choose instead of paying more for an extra top panel and wasting one, however, still glad I managed to get my order in on the 4th of Jan and receiving it in Jan.
Reactions: Handy
BartHaare
Hello, is it possible to mount two pairs of 3.5" drive brackets to the side fan bracket? Or mount one pair to the side and one on the bottom of the case if I'm not using a GPU? (V6.1)
Necere
3,300
The TG side panel will be available through w360mod.
I think we should have some ODD top panels available this month.
You could do two on the side and one on the bottom for up to six 3.5" HDDs, if you wanted.
Reactions: BartHaare
2,740
2,876
Spokane, WA
I had 2 sets of brackets mounted to the fan bracket in my v5.0, just remember you will need a low profile cooler. Not having a GPU works really well, I had 2 x 120mm fans mounted as intake on the bottom and it kept my drives nice and cool.
Handy
I wish that that will happen too. Just like when i ordering my v.3.0 in 2015. We can chose with or with odd panel
MightyBoo
When will the front i/o kit with USB-C be made available? Its been over 6 months and still OOS. (V2 + Asus Z390i Strix). TIA.
BartHaare
That sounds great, do you know the exact clearance for the CPU cooler? I think the Noctua NH-L9 should work right?
No Hands 55
Has anyone put an Accelero on a 5700xt yet? looking to get a new gpu and already have the accelero in my Ncase and would like to use it again, but im seeing a lot gpus that are just deshrouded instead of using the Accelero
Necere
3,300
anxiously waiting for window panel and odd slot top panel >.<
and just like that, v5 owners left in the dust, no accessories, no extra panels, nada. ?
We have panel kits and ODD top panels already, just a matter of whenever w360 wants to start taking orders for them.
We should also have front I/O kits ready by the end of the month.
