NCASE M1 V6 GPU Compatibility List
yimingwuzere
28
Tried out using 2x Phanteks T30s for deshrouded GPU fans. These seem to work well with the Zotac 3080 Trinity/Holo as well as the 3090 Trinity.
Zotac's 3080 Ti cards appear to use a 5mm thicker heatsink so those cards are probably better off on NF-A12s instead.
P.S. Don't expect wonders with noise levels from these fans, unlike what reviews indicate when used with AIOs for CPU cooling. They're more flush with the Zotac 3080s whereas my previous Gentle Typhoons required spacers, but it has the same issue with turbulence causing a lot of noise like Zotac's 3080 stock fans - both became unbearably loud past ~70% fan speeds on the stock fan speed mode. Didn't have the same issues with noise when using Gentle Typhoons at 1850rpm.
der_brennesel
Headsup: Watercool Heatkiller V RX 6800 / 6900 XT does fit the Ncase M1.
It leaves a total of .5mm space between the terminal and sidepanel!
I can confirm that it physically fits and there still is a extremely tiny Gap between terminal and side panel. Max fitting outer diameter is 20mm!!! Use 90° rotary for bigger fittings.
hlives
If you want to attach Colorful iGame GeForce RTX 3080 Vulcan to Ncase M1, you can gpu deshroud
hello could you post more details after full installed ? i have leaved message in your imgur too. hoping for your reply
Mannyac
Do you still have enough space under the graphics card for a raditor and 2 fans?
It doesn't work with my current Bykski on the Vega 64.
der_brennesel
I have a TX240 + 2 Noctua A12x15s under it.
Overall Performance was best with both fans set as exhaust pulling air through the Radiator. In Push mode i had very high SSD Temperatures on my back mounted SSD. It's also possible to keep the I/O panel this way - The reference Card is short enough to route tubing above it (you need 2 30mm G1/4 extenders + 90° Fittings) and the Radiator will clear the I/O Panel cables with fans underneath it.
Penguin
40
So I ordered the GPU block I mentioned earlier and after 7ish months it did arrive! The result is a dual radiator Ncase build with front IO and a Asus 3080 TUF.
exe222
Do we already have information on the upcoming generation?
AMD is yet to come, but are there already NVIDIA specs out? I Could not find the dimensions but expect them to be too large...
exe222
Now that AMD is ready as well: Any news on that?
267x135x50mm could be a tight fit. Would be great if anyone found confirmation. :)
JarekLB
what radiator is that on the side, it looks way thicker than the xspc one.
Necere
NCASE
3,261
Depends on how much room the power connector has, but otherwise the reference AMD 7900 looks like it should (just) fit.
Reactions: exe222 and JarekLB
Yota79
I’ve found this specs for the 7900xtx:
Dimensions
Length
287 mm
Slot Size
2.5 slots
it’s fit in the case? I don’t know if is to lenght about 7cm for the front panel, I don’t like to remove…
paulesko
402
308
287*135*50
it would fit I think, but it´s going to be very very close to the side panel. you´ll probably need a 180 degree connector on the side
Yota79
287*135*50
Ok thank you very much. Now I have the 6900xt AMD and also have the 180 degree 8 pin connector for the power.
i think the problem is the lenght and not the width
paulesko
402
308
the 7900 xt/xtx is 287 inlenght and 50 mm in thicknes
the specs of the case says that 320mm for 45 thick gpus and 280 por 45 to 60 mm thick gpus... it´s going to be close.
Divij
Hello, just wanted to ask if the Inno3D 4070ti X3 (297mm x 118mm x 42mm) will fit in this case.
My understanding from looking at the diagram is that it should without removing the front IO. This seems to be the only 40 Series card that does.
Any red flags will be appreciated before I purchase this. Currently I have 2 15mm fans mounted at the bottom as intake. Will that be okay?
Thanks for the help!
2,413
2,489
If you check this reddit post you will see the MSI Ventus 4070 Ti also fits.
