NCASE M1 V6 GPU Compatibility List
ClawSS
The more I look at images of the Tuf in the M1, the more I think it was sized exactly for it (both M1 for it and it for the M1). Even if it is a mild chore to install, the card can cool the best of all AIO cards and with the M1 V6.1 side panels will let it vent just fine without aux. fans. I have 2x 25mm Noctuas that were waiting, but with this one, I think they are just shelf candy for now.
Now I wait on the 6800XT reviews and the ZEN3 accoutrement. This is fun (frustrating but fun) and the lack of availability really helps me not buy too quick and make more informed decisions.
Reactions: Plaklijm
TheSpiderGuy
This is not an exhaustive list, focused primarily on current gen top-tier cards (as these tend to be the largest). Downrange models often share designs with higher end models, so this should still be useful for determining compatibility with many of those cards. Note that until verified by users, compatibility is a best guess based on published specs and product photos, and will tend to be conservative.
Generally speaking, nvidia and AMD reference/Founder's Edition cards will always fit.
____________________________
GPU compatibility (M1 V6)
Graphics Card Support
Maximum length​
  • 322mm (cards up to 45mm (2.2 slots) thick)
  • 280mm (cards up to 60mm (3 slots) thick)
  • 300mm (cards up to 60mm (3 slots) thick with front I/O ports removed)
Maximum height (AKA width)​
  • 140mm at mid-card
  • 130mm (first 5mm at back corner)
  • 125mm (portion of card over 280mm long)
  • Please allow 15-20mm for PCIe power connectors
Bottom fan support​
  • 25mm thick fans: 2-slot (<42mm) cards only
  • 15mm thick fans: up to 2.5-slot (<50mm) cards
GPU support bracket​
  • 2 to 2.5 slot (<42mm-50mm) cards only
Detailed length/height diagram:
Please note this shows the maximum internal dimensions and does not account for card installation.
Example of a reference height card (PCB/cooler =~111mm tall) - no recessed connectors:
Example of a tall card (PCB and/or cooler over 111mm tall) - no recessed connectors; height added by PCIe power connectors can prevent installation in narrower cases:
Example of a tall card with recessed PCIe power connectors - reduced overall height may allow installation in more cases:
Where low profile PCIe power adapters are indicated for fitment, ModDIY connectors are suggested.
AMD Card Compatibility List
ManufacturerModelLengthHeightThickness (slots)NotesCompatible?Fitment Notes
AMDRX 6900/6800 XT267120~50YesMight need low profile PCIe power adapters
AMDRX 680026712040YesMight need low profile PCIe power adapters
* Front I/O ports must be removed
§ Low profile PCIe power adapters must be used
† Installation may be difficult
ASRockRadeon RX 5700 XT Challenger D 8G OC?12142Yes
ASRockRadeon RX 5700 XT Taichi X 8G OC+31113053Recessed power connectorsNo
ASRockRadeon RX 5700 XT 8G (AMD Reference)27011142Yes
ASRockRadeon RX 5700 Challenger D 8G OC?12142Yes
ASRockRadeon RX 5700 8G (AMD Reference)27011142Yes
ASRockPhantom Gaming X Radeon VII 16G (AMD Reference)26712140Yes
ASUSTUF Gaming X3 Radeon RX 5700 XT OC edition26912554Yes
ASUSROG Strix Radeon RX 5700 XT OC edition30513054Recessed power connectorsYes*†Confirmed by user
ASUSAMD Radeon RX 5700 XT (AMD Reference)27011140Yes
ASUSTUF Gaming X3 Radeon RX 5700 OC edition26912554Yes
ASUSROG Strix Radeon RX 5700 OC edition30513054Recessed power connectorsYes*†
ASUSAMD Radeon RX 5700 (AMD Reference)27011135Yes
ASUSRadeon VII (AMD Reference)26712140Yes
GigabyteRX 5700 XT GAMING OC 8G280114.349.6Yes
GigabyteAORUS Radeon RX 5700 XT 8G29012358Yes*†
GigabyteRX 5700 GAMING OC 8G280114.349.6Yes
HISRadeon RX 5700 XT (AMD Reference)27211136Yes
HISRadeon RX 5700 (AMD Reference)26811136Yes
HISRadeon VII (AMD Reference)26812042Yes
MSIRadeon RX 5700 XT GAMING29714058No
MSIRadeon RX 5700 XT GAMING X29714058No
MSIRX 5700 XT MECH OC23212646Recessed power connectorsYes
MSIRX 5700 XT EVOKE OC25412951Recessed power connectorsYes
MSIRadeon RX 5700 XT 8G (AMD Reference)27011040Yes
MSIRadeon RX 5700 GAMING29714058No
MSIRadeon RX 5700 GAMING X29714058No
MSIRX 5700 MECH OC23212646Recessed power connectorsYes
MSIRX 5700 EVOKE OC25412951Recessed power connectorsYes
MSIRadeon RX 5700 8G (AMD Reference)27011040Yes
MSIRadeon VII 16G (AMD Reference)26712140Yes
PowerColorRed Devil Radeon RX 5700 XT30013253Yes*§†Confirmed by user
PowerColorRed Dragon Radeon RX 5700 XT24013241Yes§
PowerColorRadeon RX 5700 XT23011141Yes
PowerColorRadeon RX 5700 XT 8GB DDR6 (AMD Reference)27011140Yes
PowerColorRed Devil Radeon RX 570030013253Yes*§†
PowerColorRed Dragon Radeon RX 570024013241Yes§Confirmed by user
PowerColorRadeon RX 570023011141Yes
PowerColorRadeon RX 5700 8GB DDR6 (AMD Reference)27011140Yes
PowerColorRadeon VII (AMD Reference)28012540Yes
SapphireRadeon RX 5700 XT (AMD Reference)27211136Yes
SapphireNITRO+ RX 5700 XT 8G30613549Recessed power connectorsYesConfirmed by user; sits at slight upward angle due to front I/O
SapphirePulse RX 5700 XT25413546.5Recessed power connectorsYes
SapphireRadeon RX 5700 (AMD Reference)26811136Yes
SapphirePulse RX 570025413546.5Recessed power connectorsYesConfirmed by user
SapphireRadeon VII (AMD Reference)26812042Yes
XFXRadeon RX 5700 XT RAW II27814058Recessed power connectorsYesConfirmed by user
XFXRadeon RX 5700 XT Triple Dissipation~315~13344Recessed power connectors
Possibly sold as THICC III Ultra
XFXRadeon RX 5700 XT THICC II (incl. Pro/Ultra)29313055Recessed power connectorsYes*†
XFXRadeon RX 5700 XT THICC III (incl. Ultra)31513157Recessed power connectors
Original 3-slot model per XFX website; retail model may have been replaced by the 2-slot Triple Dissipation design
No
XFXRadeon RX 5700 XT (AMD Reference)26711140Yes
XFXRadeon RX 5700 (AMD Reference)26711140Yes
XFXRadeon VII (AMD Reference)28012540Yes
Nvidia Card Compatibility List
NvidiaFounder's Edition RTX 30903131383-slotNo
NvidiaFounder's Edition RTX 30802851122-slotYesConfirmed by user
NvidiaFounder's Edition RTX 30702421122-slotYes
ASUSROG STRIX RTX 3090/3080/3070318.5140.157.8No
ASUSTUF RTX 3090/3080299.9126.951.7Yes*§†
ASUSDUAL RTX 3070 8G26713552No
EVGAXC3285.37111.152.2-slotYesConfirmed by user
EVGAFTW3300136.752.75-slotYes*§†Confirmed by user
GainwardRTX 3090/3080 Phoenix/Phoenix GS2941122.7-slotYes*†
GalaxRTX 3090/3080 SG31711361No
GalaxRTX 3070 SG317113~2.5 slotYesConfirmed by user
GalaxRTX 3090/3080/3070 EX Gamer31612458No
GalaxRTX 3070 EX28512458Yes§
GigabyteAORUS RTX 3090/3080 XtremeNo
GigabyteAORUS RTX 3090/3080 Master31914070No
GigabyteRTX 3090/3080 Gaming OC32012955No
GigabyteRTX 3090/3080 Eagle OC32012856No
MSIRTX 3090 Gaming Trio/Gaming X Trio33514056No
MSIRTX 3080 Gaming Trio/Gaming X Trio32314056No
MSIRTX 3090/3080 Ventus 3X30512057Yes*†Confirmed by user
MSIRTX 3070 Ventus 3X30512152Yes*†
MSIRTX 3070 Ventus 2XTBD
PalitRTX 3090/3080/3070 GamingPro29411260Yes*†
PNYRTX 3090/3080/3070 XLR8 Gaming EPIC-X RGB Triple Fan29411259Yes*†
ZotacRTX 3090 Trinity317.8120.758Yes*†Confirmed by user
ZotacRTX 3080 Trinity317.8120.758No
Zotac3070 Twin Edge231.9141.341.5No
ASUSDual GeForce RTX 2080 Ti26811458Yes
ASUSDual GeForce RTX 2080 Ti OC edition26811458Yes
ASUSTurbo GeForce RTX 2080 Ti26911442Yes
ASUSROG Strix GeForce RTX 2080 Ti304.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce RTX 2080 Ti Advanced edition304.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce RTX 2080 Ti OC edition304.7130.454.1Recessed power connectorsYesConfirmed by user
ASUSROG Matrix GeForce RTX 2080 Ti31013559.6Recessed power connectorsNo
ASUSDual GeForce® RTX 2080 SUPER EVO26711856Yes
ASUSDual GeForce® RTX 2080 SUPER EVO OC edition26711856Yes
ASUSROG Strix GeForce® RTX 2080 SUPER299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2080 SUPER Advanced edition299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2080 SUPER OC edition299.7130.454.1Recessed power connectorsYes
ASUSDual GeForce RTX 208026811458Yes
ASUSDual GeForce RTX 2080 Advanced edition26811458Yes
ASUSDual GeForce RTX 2080 OC edition26811458Yes
ASUSTurbo GeForce RTX 2080 Evo268111.340Yes
ASUSROG Strix GeForce® RTX 2080299.7130.454.1Recessed power connectorsYesConfirmed by user
ASUSROG Strix GeForce® RTX 2080 Advanced edition299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2080 OC edition299.7130.454.1Recessed power connectorsYes
ASUSDual GeForce® RTX 2070 SUPER EVO26711858Yes
ASUSDual GeForce® RTX 2070 SUPER EVO Advanced edition26711858Yes
ASUSDual GeForce® RTX 2070 SUPER EVO OC edition26711858Yes
ASUSTurbo GeForce® RTX 2070 SUPER EVO268111.340Yes
ASUSROG Strix GeForce® RTX 2070 SUPER299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2070 SUPER Advanced edition299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2070 SUPER OC edition299.7130.454.1Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2070300.5130.648.9Recessed power connectorsYesConfirmed by user
ASUSROG Strix GeForce® RTX 2070 Advanced edition300.5130.648.9Recessed power connectorsYes
ASUSROG Strix GeForce® RTX 2070 OC edition300.5130.648.9Recessed power connectorsYes
EVGAGeForce RTX 2080 Ti XC GAMING27011140Yes
EVGAGeForce RTX 2080 Ti XC ULTRA GAMING27011154Yes
EVGAGeForce RTX 2080 Ti XC2 ULTRA GAMING27011154Yes
EVGAGeForce RTX 2080 Ti BLACK EDITION GAMING27011140Yes
EVGAGeForce RTX 2080 Ti GAMING26511140Yes
EVGAGeForce RTX 2080 Ti XC HYBRID GAMING26611440Attached 120mm AIOYes
EVGAGeForce RTX 2080 Ti FTW3 GAMING30213954No
EVGAGeForce RTX 2080 Ti FTW3 ULTRA GAMING30213954No
EVGAGeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING29113940Attached 120mm AIONo
EVGAGeForce RTX 2080 Ti FTW3 ULTRA HYDRO COPPER GAMING291158.540WaterblockNo
EVGAGeForce RTX 2080 Ti K|NGP|N GAMING29113940Attached 240mm AIONo
EVGAGeForce RTX 2080 SUPER XC GAMING27011140Yes
EVGAGeForce RTX 2080 SUPER XC ULTRA GAMING27011154Yes
EVGAGeForce RTX 2080 SUPER XC2 ULTRA GAMING27011154Yes
EVGAGeForce RTX 2080 SUPER XC HYBRID GAMING26611440Attached 120mm AIOYes
EVGAGeForce RTX 2080 SUPER BLACK GAMING27011140Yes
EVGAGeForce RTX 2080 SUPER GAMING27011140Yes
EVGAGeForce RTX 2080 SUPER FTW3 ULTRA GAMING30213954No
EVGAGeForce RTX 2080 SUPER FTW3 HYBRID GAMING29113940Attached 120mm AIONo
EVGAGeForce RTX 2080 SUPER FTW3 HYDRO COPPER GAMING291158.540WaterblockNo
GainwardGeForce RTX 2080 Ti Phoenix29211250No*
GainwardGeForce RTX 2080 Ti Phoenix GS29211250No*
GainwardGeForce RTX 2080 SUPER Phantom29213054No
GainwardGeForce RTX 2080 SUPER Phantom GLH29213054No
GalaxGeForce® RTX 2080Ti SG Edition30811147No
GalaxGeForce® RTX 2080Ti HOF33014557No
GalaxGeForce® RTX 2080Ti HOF 10th Anniversary Edition32016558No
GigabyteGeForce RTX 2080 Ti GAMING OC 11G286.5114.550Yes
GigabyteGeForce RTX 2080 Ti WINDFORCE 11G280.4116.540Yes
GigabyteGeForce RTX 2080 Ti WINDFORCE OC 11G280.4116.540Yes
GigabyteGeForce RTX 2080 Ti TURBO 11G267113.735Yes
GigabyteGeForce RTX 2080 Ti TURBO OC 11G267113.735Yes
GigabyteAORUS GeForce RTX 2080 Ti TURBO 11G271112.536Yes
GigabyteAORUS GeForce RTX 2080 Ti 11G290134.360YesConfirmed by user
GigabyteAORUS GeForce RTX 2080 Ti XTREME 11G290134.360YesConfirmed by user
GigabyteAORUS GeForce RTX 2080 Ti XTREME WATERFORCE 11G29013140Attached 240mm AIONo
GigabyteAORUS GeForce RTX 2080 Ti XTREME WATERFORCE WB 11G291.315928.7WaterblockNo
MSIGeForce RTX 2080 Ti VENTUS GP26811250Yes
MSIGeForce RTX 2080 Ti VENTUS 11G26811250Yes
MSIGeForce RTX 2080 Ti VENTUS 11G OC26811250Yes
MSIGeForce RTX 2080 Ti VENTUS 11G OCV126811250Yes
MSIGeForce RTX 2080 Ti SEA HAWK X26811441Attached 120mm AIOYes
MSIGeForce RTX 2080 Ti LIGHTNING32814363No
MSIGeForce RTX 2080 Ti LIGHTNING Z32814363No
MSIGeForce RTX 2080 Ti GAMING TRIO32714056.5No
MSIGeForce RTX 2080 Ti DUKE 11G31412050No
MSIGeForce RTX 2080 Ti DUKE 11G OC31412050No
MSIGeForce RTX 2080 Ti SEA HAWK EK305169.341.5WaterblockNo
MSIGeForce RTX 2080 Ti SEA HAWK EK X305169.341.5WaterblockNo
MSIGeForce RTX 2080 SUPER VENTUS26811450Yes
MSIGeForce RTX 2080 SUPER VENTUS OC26811450Yes
MSIGeForce RTX 2080 SUPER AERO26511440Yes
MSIGeForce RTX 2080 SUPER GAMING TRIO32814056.5No
MSIGeForce RTX 2080 SUPER GAMING X TRIO32814056.5No
PalitGeForce RTX 2080 Ti GamingPro29211258No*
PalitGeForce RTX 2080 Ti GamingPro OC29211258No*
PalitGeForce RTX 2080 Ti Dual29211258No*
PalitGeForce® RTX 2080 SUPER GR29213059.6No
PalitGeForce® RTX 2080 SUPER GRP29213059.6No
PNYGeForce RTX 2080 Ti 11GB XLR8 Gaming Overclocked Edition30211438Yes
PNYGeForce RTX 2080 Ti 11GB Blower26711438Yes
ZotacGeForce RTX 2080 Ti Twin Fan26811338Yes
ZotacGeForce RTX 2080 Ti Blower26811338Yes
ZotacGeForce RTX 2080 Ti Triple Fan30811357No
ZotacGeForce RTX 2080 Ti AMP MAXX29813342No
ZotacGeForce RTX 2080 Ti AMP30811357No
ZotacGeForce RTX 2080 Ti AMP Extreme32413659No
ZotacGeForce RTX 2080 Ti AMP Extreme Core32413659No
ZotacGeForce RTX 2080 Ti ArcticStorm29515830WaterblockNo
Is Gigabyte's Vision series of GPUs compatible?
GB223
Where are you getting all those 3080's tuf from? Being trying to get one ever since launch and it's always unavailable..
Plaklijm
164
87
3070 will fit, the 3080/3090 are too big.
I know in my country you can order one and then you are put on a waitlist. And every card that comes in just is giving to the person highest on the wishlist. But in other countries it is different and it just launches and you have to be lucky to get one
radnox
The fan still touch the cable even you put 2 fans under it?
Well I removed a bit of the connector’s plastic so it won’t even without fans now. But I think it would still touch it with them. I also added a little anti-sag lego support to level and future proof my install.
radnox
I ordered mine from the eu asus webshop. I was on a discord channel to help me to get notifications on stocks. I don’t know if sharing these kind of links here is allowed here. I think you can find it easily under « nvidia stock parts alerts discord ».
Reactions: GB223
impreza7854
Hello,
I have an N-Case M1 V6 and I purchased a Galax/KFA2 RTX3070 SG and I was able to fit in the card with 1-2mm to spare. I had to remove the front panel to insert the GPU and reattach / close the front panel securely. I just needed to do some minor cable routing to allow room for the card to connect properly.
I am actually in the process of water-cooling my pc but haven't received all the parts as yet.
I have a photo of the card inserted and the box of the gpu, but I am unsure how to add it, if possible, to this message?
I noticed on you supported GPU list that this card was NOT supported but it does fit :)
Just thought you'd like to know.
Regards
I also installed Galax RTX3070 SG in my M1 V6, but I couldn't put the front panel back to the case. It stuck with the card. Can you show me the photo of yours.
Thank you so much.
wzhalex
49
will the new EK water block for 3080 FE fit if I want to put a 22mm radiator(XSPC TX240) and a 15mm fan at the bottom? The width of the water block including the backplate is 29mm .
Thanks.
Teletubby89
79
56
Pre Ordered the FE EKWB block in black, will slip in the tx240 and chromax fans i think underneath. Price was more than i expected though must admit.
Reactions: Plaklijm
wzhalex
49
I preordered too! Just wonder if we can fit it in since it is 29mm in width. Really worried about it.
Is 29mm a lot thicker than the typical water block? Or the typical 21mm water block plus the PCB and the back plate will also add up to around 29mm?
Anders
Possibly the 29mm is referring to the whole assembly of water block and backplate.
Using the EKWB water block for the XC3 as an example, its 20.75mm + 5.20mm (Block + backplate), not including the thickness of the actual gpu in between.
wzhalex
49
Using the XC3 as an example, its 20.75mm + 5.20mm (Block + backplate), not including the actual gpu board thickness
I emailed EK they said that 29mm is with everything including the block, gpu and the backplate, so I think it should fit.
By the way, if it does not bother too much, would you please help me to measure the width of the water cooled XC3?(Block GPU and backplate) how much headroom for the bottom fan? just try to confirm that this new water block fits or not.
Thank you so much!
