The MT5 case supports a variety of mini ITX hardware. Switching gears a bit from the original 4 liter concept, this case is now 5.1 liters in volume to support more power supplies. It can be configured for Flex-ATX PSUs or HDPLEX/MeanWell setups. The frame is built with corner pieces printed from ABS plastic, with acrylic case panels. There will be several color options for this case to make it more customizable.
A notable feature of this case is its two-piece design, which adds the possibility to expand the case for more compatibility, such as taller CPU coolers or extra wide GPUs.
Update - December 24, 2019
Pre-production version in progress
Case parts are currently in production for the prototype for parts fitting and thermal testing. New angled design using corner pieces because it is much easier to produce in quantity, in sheets using various materials.
Case specifications:
- Material: FDM printed plastic with acrylic panels
- Dimensions: 190mm x 227mm x 109mm (4.7 liter volume)
- Motherboard: Mini-ITX
- Graphics card: dual-slot, max length 175mm
- Storage: m.2 plus up to 2 x 2.5
- CPU cooler: max height 40mm
- Power supply: Flex-ATX or custom AC-DC setup of 200-500W
- Case colors: Black, white
This is the last prototype for the case. The final dimensions have since changed from this prototype.
Pictures of the first prototype (made with MarkForged Onyx)
Survey for those interested in purchasing
So yeah, it's a very generic title but this is what I've started working with for my next case project. First off is a vertical GPU mounting case with motherboard facing back-to-back which is becoming more standard fare.
But there's still very few options available and wanted to have my go at it since I have wanted a layout like this more for its short height and portability.
This case is inspired by the Circle cases a bit for style, but also by the Jottwehh 3.99 liter case for layout and being 3D printed (mine is somewhat bigger). The Jottwehh looked very promising but development unfortunately came to a halt. Same with the Hutzy XS. The last two cases in this list have mini GPU support with some sort of internal PSU support. I want to do the same.
Here is what I have of the design so far. Most of the outer shell is done, but now onto the interior pieces like the motherboard tray, and other parts for mounting components and accessories.
Here's a full preview render of the case so far, pictured with a GPU, SSD and Dynamo 360.
The case is to be made of four main parts that join together on the inside. The only visible exterior screws will be on the side panels, and the base (only seen from underneath).
The side windows will be acrylic, either in clear, smoke tint, or opaque colors. The top and bottom sections have large openings that can be used to attach different ventilation panels inside. There's also more customization options, but more on that later.
I originally intended this design to be made specifically for 3D printing, but with some very minimal tweaking it can also be suitable for CNC milling. Machined aluminum will look great but also more expensive in small numbers.
Also I will go team AMD for my next build and really want to showcase an Radeon card with Ryzen CPU. There really need to be more options for mini cards, but I am going to go with an older gen Radeon first.
MT4 case survey
More information about the case can be viewed here: https://smallformfactor.net/forum/threads/mt4-4-5l-expandable-case-for-mini-gpus.8510/ Submitting this form doesn't commit a final purchase for this case, but to receive notifications on when the case is launched or other major updates.
forms.gle
