Any geniune DDC fits. Would recommend one with PWMI've just put my order in for a new build! A quick question - can other DDC pumps be used (4.2 or others?), I'm having a hard time sourcing a PWM 3.1 DDC...sorry if it has been covered, didn't see it in my skim of all the pages.
Edit: my main option is a DDC310 from alphacool, it does not have PWM but appears to be silent from reviews and postings at 100% flow...
Would be happy to test an AM5 version of this :-) 7950X and 7900X delidded and ready to goUnfortunately there is not much to update. Still waiting on the beta testers to post their results. I don't have any of the components to test with so I am relying on them to report back when they are done.
Nice work, thanks again Victor.Hey Guys!I have another one for you.
This time the Modultra LOBO by @Alloy Craft was used inside the SSUPD Meshroom S with two different Radiator Setups. Both 280mm, but one XT45 with Slim Fans (Arctic P14) and the ST30 Radiator with regular 25mm Fans.
It was tested with a ton of heat to dissipate! (Intel Core i9-12900K)
Hope you like the video:
Plating looks pretty good, you mind sharing who did it for you?I had mine chemically nickel plated. ~10 micron layer.
some photos attached.
I will now sand it with 7000 grit sand paper and then polish it for a mirror finish.
In hindsight, I should have done this before the plating.
LOBO direct die kits are in stock ready to ship.Wanted to toss my hat in as interested in a direct die kit for 1700
