Ok so I have two different design layouts I am looking into. The first is an updated version of the concept 2 posted before. This case has dimensions of 270mm x 220mm x 100mm for a volume just under 6L. Max GPU length will be about 212mm which means it should be able to fit up to the GTX 1080Ti Mini. The downside is that it can only support custom waterloops with a dual 80mm rad.
6L Layout:
The second layout requires no PCIE riser and has support for the Cooler Master MasterLiquid Maker 92 AIO or a standard 120mm AIO mounted to the side panel. It also can support the dual 80mm rad and a traditional pump/res combo. Its dimensions are 215mm x 215mm x 145mm for a volume of 6.7L. The downside to this design is that GPU height becomes a concern (although it should fit the Gigabyte 1070) and has a max GPU length of only about 195mm.
6.7L Layout:
The second layout to me seems to be much more compact even though it has a larger volume but has compromises to GPU length in order to keep it under 7L. If I wanted to fit the GTX 1080Ti Mini in this case layout it would likely increase in volume to about 7.7L.
6L Layout:
6.7L Layout:
