Old design, probably will never see the light of day anymore.Will we see this style glass in future?
The glass panels looked different on sale site.
Can't wait to see it !! I was waiting for some kind of update and a video would be AWESOME. But, is the video going to be about how random parts are CNC'd or show us how mjolnir is been CNC'd (meaning production has begun!)?Yeah that's an old and comparably bad design (especially from a structural standpoint) ? Btw, going to put together a KS update very soon. We're waiting for some videos from the factory, want to show you guys how the parts are CNCd, bead blasted and anodized.
Cheers
Alex
Yes I agree with @Paul_the_Octopus, If its not directly footage from the MJOLNIR I do no think it would be received well if you show off manufacturing steps for a different product (even if it is from the same factory).Yeah that's an old and comparably bad design (especially from a structural standpoint) ? Btw, going to put together a KS update very soon. We're waiting for some videos from the factory, want to show you guys how the parts are CNCd, bead blasted and anodized.
Cheers
Alex
Hello guys, I'm trying to build my first itx computer, I'm not sure if the mjolnir can fit a strix 2080 TI OC, I hope someone can help me out! Thank you ?
I saw the picture released today.
Is the plastic guide bolted, not adhesive? It is a very satisfactory matter.
I want to know the expected life span of plastic and metal friction.
Can I buy spare parts?
Heey! ? I'm not certain of the dimensions, but I think it's a bit to wide unfortunately :/ Does anybody have the dimensions for that GPU?
The plastic (Nylon) corner guards are fixed via adhesive, the holes are used to guide them in correctly and provide some "gripping" force. Lifespan under normal use (build 4 times per year) will last a LOOOONG time, especially since we use self-lubricating nylon. Also, MJOLNIR will have a "smooth" anodized coat, which further decreases friction.
ps. that dark-gray (DARK) turned out pretty nice right? ? Will take some better pics once we receive the samples next week. As mentioned in the update, the manufacturer wanted to remake the samples in a different aluminium alloy (6063 instead of 6061-T6) because they weren't satisfied with the anodized finish (looked great to me, but hey...if the can make it even better than why not right? ?)
Welcome! I would also like to add a few questions to this @AlexTzone. What company are you guys going to use for shipping (i really hope its fedex or dhl, since my country’s regular courrier is absolute garbage). And if using more then one, do we get to choose ?hey guys! Just made a sff forum account to post in this thread and keep up to date on Mjolnir. I ordered an rgb Mjolnir in dark with the booster cell and 2x panels back in June.
A couple quick questions; What are the updates on the gen 4 pcie riser cable? Are the cases being shipped straight from the factory in China to us (buyers)?
I'm so excited for the update next week with sample pictures! You guys are awesome!!
I've recommended a Mjølnir XL that might be a little bit wider (not much) and about 3 cm taller, so you can fit 240 and a proper high end gpu and still use glass panels. I hope they will make it happen. MIght even be able to reuse the panels and such as no one needs to see the fans/radiator anyways. Once everything is done with small mjølnir I think it would be a lot faster to make their next case, especially if it's only a modification. Let's hope.Is there any plans to make a version of the case that supports 3 slot gpu and 240 AIO?
@AlexTzone Just wanted to share this horror story with you. One of the Kickstarter projects I had backed was to produce a single screw. Yes, really, one single screw (Link). And while things were delayed by Corona and what not, they managed to pull off their production and people are starting to get their screws now.
Turns out, that none (or at least, the vast majority) of the production units are not within the tolerance needed for the use-case. It would seem that the factory used had been in fact sending the project leader "Cherry-Picked" samples as "Randomly-Picked" samples and so while everything looked fine and the guy gave the go ahead for full-scale manufacturing, most of what came off the line was unusable. So now that the factory has fulfilled its "full-scale manufacturing" after getting the green light from the creator, I guess they feel their job is done.
So I guess the take home from this is to not trust samples sent by the factory and the importance of really inspecting what is coming off the line in a true random fashion. Furthermore I guess if you use a 3rd party for inspection, you better have a 3rd party auditing that 3rd party, otherwise I wouldn't put it past anybody to issue a small bribe or once again show a golden sample.
Given that this was for one single screw, imagine the potential for slackness of something as complicated as MJOLNIR.... I really hope you can get somebody you know personally in those factories to inspect the production units.
