GOAT NANOQ build, absolutely insane. It's not only maxed out in terms of rad space, but also so minimalistic (the GPU compartment looks basically empty). I'll try to do a similar look myself once that GPU block becomes available.
That block is gorgeous and so compact.GOAT NANOQ build, absolutely insane. It's not only maxed out in terms of rad space, but also so minimalistic (the GPU compartment looks basically empty). I'll try to do a similar look myself once that GPU block becomes available.
@AlexTzone will it be possible to convert a v1 case fully to a v2?
I have my v1 still unopened waiting for hardware and would like to know if I can purchase the parts needed to convert it to a v2.
I think the v2 upgrades are big enough to that I want to do it.
@AlexTzone I want to replace the Riser in my Mjolnir with a real PCIe Gen4 cable. What length and type should I order from ADT-link to fit in the Mjolnir?
PCIe x16 Extension Cable
Is there an available thickness of the Tetra cases (any of them)? I.e. the "height" when it's in its lying down position? Trying to figure out if it will fit in my desk
Unrelated; Shouldn't this thread be renamed to something like Thorzone or something since it's not only about the Mjolnir anymore but also about NANOQ (and now Tetra)?![]()
