I'd wager most people are probably going M.2 only.Just looked at some of the new mobo's coming out and an interesting question came up... Is the new [B550 ASRock ITX-AX](https://www.asrock.com/mb/AMD/B550%20Phantom%20Gaming-ITXax/index.asp) not compatible because of the orientation of the SATA ports? A normal cable is going to run into the PSU, but a right angle is going to go down into the spine. Actually now that I think about it I'm sure a lot of people will be content with M.2 drives only, but it's an interesting limitation.
I didn't know those were a thing. Thanks for pointing them out to me.those super-slim SATA cables from Silverstone may work.
I had good luck with them in an older NCase build that I had a while back. I went with them to hide them because I wasn't confident on wire sleeving back then. They hid really well behind other braided cables where you almost couldn't even notice them. Certainly small.I didn't know those were a thing. Thanks for pointing them out to me.
Alex, quick question for you;
When you're assembling the cases for shipping, will the silicon pieces on the core backing-plate, that is the rear I/O panel of the case, be pre-installed before we receiver our cases? I'd like to do something custom with the back panel and get it re-anodized a particular color. It's not a huge deal, just trying to figure out before-hand everything I need, including more adhesive for those silicon parts if I need to remove them to re-anodize the panel.
Easy enough! The shop I think is one your page follows on Instagram, they seem quality. I'm sure it'd be easy for them.Heey Justin, basically everything will be assembled before you guys receive the case ? Those corner guards are pushed in and fixed with adhesive, I'm not so experienced when it comes to remove a glued plastic part without damaging it. Perhaps a hairdryer or heat gun on low setting?
Also, super important to let the anno shop know that there was glue on the panel. Even very small traces of glue will prevent anodizing on those areas.
Not a terrible idea. It might eat up some usable real estate if it's too tall though?@AlexTzone do you have comparisons of the new rigid LED strips in terms of their diffuseness and illumination angle? If it's too "spotlighty" you might want to consider a transluscent light diffuser?
Hello @AlexTzone , hope you are doing great (like everyone else btw).
I have a recommandation. What about tinted tempered glass ? I think it would look so much nicer. We would see less the cables and the leds would stand out much better ! Few years ago I had a jonsbo case with a beautiful tinted tempered glass. See the results.
So what do you think ? ☺
(Pardon my english)
Alex, my friend, I'm sure the strips intended to be sold with the case are compatible but, just for peace of mind sake:
I plan on using the ASUS ROG STRIX Z490-I Gaming motherboard, which has an addressable "gen 2" 5V header. I didn't know there was a "gen 2" for RGB hahaha. This is what they list in their manual. Is this compatible with the LED strips that will come with the case?
Are there any real pictures comparing the colors? Hard to get an idea from renders.
