Should be possible to attach the distro to the screw holes for the drive bay. You'll have 20mm of height to work with (unless you remove the front cap, in which case it would be 25mm)Cool, I'll get those dimensions!
I can definitely help out with the internal dimensionsJust let me know which numbers you wants to know.
Ok, I'm sold on the new Silicon feet. The more I think about it, the more I realize that it will still have a premium feel. Especially with the recessed channel that they will fit into.
Well done.
Yeah I was actually already considering the H60! and as for the LPX that's a good plan I may have to steal haha! I was looking at g.skill ripjaws V for the ram although ill have to check the height of those![]()
Great thanks for that! Damnit I was hoping to fit an H80i with a single fan but looks like there's barely enough clearance for the thicker radiator let alone a fan.
Between 120mm AIOs, has anyone experienced any noticeable differences? There's a few available but looking it up seems not many have done comparisons between them (I guess because in larger cases, it's typically better to do either a better air cooler or a 240mm AIO).
That would be awesome!
I assume the front green plate in my earlier picture is 5mm thick too? I’m thinking if that’s replaced too then it might give sufficient depth to mount a ddc and avoid any physical modding to the original case.
What is the height between the inside of the top rail and bottom rail (without LED strips)?
What about a [rectangular shape /bolt through type] rubber feet without glue ?
Products | ARTLINER/ARTJAPAN
www.artliner.co.jp
@AlexTzone
just saw some new design for the front panel, i wish it would be 120 x 120 x 25 because i want to use delta case fan, and dosent mind the nosie.
For those who haven't seen what @danny.nguyen is talking about, here's the update from Kickstarter:
Booster Cell (optional add-on)
Now that the front of the case has become a whole lot more flexible, we decided to put together something cool (pun intended) for those who want to push cooling even more. Not only will it allow you to install an additional 120x15 mm fan (preferably as exhaust), but it also includes a frontal power button and RGBW lighting*.
Price: <$60**
Backers with MJOLNIR R and above get $10 OFF!
*Compatible with MJOLNIR R or a digital 3-pin 5V header on your motherboard
**Subject to change, we're still working out the costs
We'll redo the mounting a bit, so that the RGB-ring and fan are mounted to the Core rather than the add-on front panel. What do you guys think?![]()
@AlexTzone Love the update. The new front panel led me down a mock up rabbit hole.
If you replaced the front of internal core (3mm), 2.5" bays (20mm) and front panel (5mm), I make it 28mm of workable depth.
This would allow a sandwich style distro plate, EK SPC pump and RES to be incorporated and bolted to the core.
My mock ups making some assumptions around things like corner radii:
smallformfactor.net
This case isn't going to be for everyone. If all the changes people wanted were to be implemented, you would have a frankencase which will be nothing like the original design and will no longer be a sff case. The more changes, the more potential problems, costs and delays will crop up in manufacturing.
Adding room for a distro plate is a VERY specialized thing for a case and not many people will use it. It's a good idea but I don't think the modifications would only be used by 1% of the backers.
If you want a case with a built in distro plate, may I recommend the following:
Stalled - DICE CASES - FLOW : expandable SFF case for watercooling enthusiast (built in distroplate)
*** MOD EDIT ------------ Original poster last seen on the forum on Feb 24, 2021 & does not seem to be responsive. Product/order related pages in the Dice website are now either inactive or password protected. At the time of this post, it seems that there are some people still waiting for...smallformfactor.net
That's my opinion, I would trust @AlexTzone to do what's best within the scope of the case and the budget. I went though this as a community mod for the ghost project and not everyone was happy that the evga FTW card would fit.
Hey @gwertheim , I think your misunderstanding my intention here. I'm making this as my own mod, for my own case. I'm not asking for any changes on the product that ships out (however if they chose to offer a distro plate as an add-on like the booster cell, then I would certainly buy it!). I have slightly rephrased the wording in my post to make it a bit clearer. ?
incidentally, there would be no change to the existing design or dimensions in using a distro plate similar to that designed, I'm trying to make this a bolt on alternative front end for the core, involving replacing only a few parts. Its inspired by exactly what they are doing with the Booster Cell (just attached to the core rather than the shell.
Yeah, finally.Less than 1 hour to go guys!! ? ?
