Hi all! An update on my case:
Parts List:
Code:| [CPU][Intel Core i9-9900K 3.6 GHz 8-Core Processor] | [CPU Cooler][Corsair H60 (2018) 57.2 CFM Liquid CPU Cooler] | [Motherboard][Asus ROG STRIX Z390-I GAMING Mini ITX LGA1151 Motherboard] | [Memory][G.Skill Ripjaws V 64 GB (2 x 32 GB) DDR4-3600 CL18 Memory] | [Storage][Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive] | [Storage][Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive] | [Video Card][Gigabyte Radeon RX 6900 XT 16 GB Video Card] | [Power Supply][Cooler Master V SFX Gold 850 W 80+ Gold Certified Fully Modular SFX Power Supply] | [Case Fan][Noctua S12A ULN 120 mm Fan] | [Case Fan][Noctua A12x25 PWM 60.1 CFM 120 mm Fan] | [Case Fan][Noctua A12x15 PWM chromax.black.swap 55.44 CFM 120 mm Fan]
Thoughts:
Case is solid built 100%. Looks fantastic and I love how compact it is on my desk.
Upon inspection of the case when delivered, no damages/scratches issues found.
Overall, I found the case to be VERY easy to put together and install/remove components.
Cable management is tricky, but it's one of those set and forget kinda things. I did get custom cables which has helped.
Orientation:
Case: Inverted (radiator on top)
Fan: Front intake, top both exhaust, side intake (my own mod)
Some note:
- Using glass panels make the case overall pretty hot. So i've resorted to just using the performance panels
- M.2 even with the mobo's cooling plate resulted in ~74-75 °C average temp and on the M.2 rear side ~70-74°C. Post side intake fan mod, temps are around ~53-57°C and ~50-53°C.
- the connector for the booster cell when inserting the Core wasn't always connecting properly when I inserted the core. So I had cut a piece of a rubber band, punched 2 holes in it and put it on the back side of the connector before screwing it into the case. Since then no issues.
Photo links:
Couldn't edit post...
