Completed MJOLNIR: The minimalistic – but not boring – 9.7L Case
Which MJOLNIR I are you interested in?
  • Standard Version - 299 USD
    Votes: 487 74.5%
  • RGB Version (No controller) - 319 USD
    Votes: 63 9.6%
  • RGB Version (With controller) - 349 USD
    Votes: 104 15.9%
  • Total voters
    654
AlexTzone
I design minimalistic – but not boring – PC stuff
Sep 23, 2017
1,355
2,841
Sweden
thor-zone.com
Is there any update on EU shipments?
Not yet, but I’m going to ask now again hoping for some good new or a date.
Just got mine, dark au! Very excited.
My only Q is, is the front panel meant to have this much give in it? I'm barely applying any force at all and can rock it a fair bit. Seems fine but just makes it very noisy when you move the case around:
Please follow this video (it’s a super easy fix):
The idea it to have the grills go as deep into the slots on the shell as possible, that way the front panel will sit rock solid! :)
Phnx
23
Have you set any deadline? If your UPS contact is contacting the receiving countries, extrapolating from the time taken to fix shipping for AU/KR it's going to be several weeks until a quote. Even now it's been a couple of weeks.
  • Love
Reactions: Shinken1
btree123
25
37
Thanks Alex appreciate it 😁 will be building it over the next few days very excited.
NotBoringCase
40
53
I'm curious to know when they're going to use the backup option. Let me guess... July 1st for EU? You can answer all our questions about how much more money do you need for shipping to Europe, we don't want you to make gold out of thin air, if budget is the problem of our cases not being sent yet.
beerbuddha
222
213
@AlexTzone made a video about it as it was first reported by someone.
Also for those who got the booster cell - it rattles a bit but once the core is inside it wont
Reactions: N9neBreak3r
AlexTzone
Sep 23, 2017
1,355
2,841
Sweden
thor-zone.com
Performed a controlled test with the Booster Cell — very positively surprised by the improvements in GPU thermals — 7°C!
Recently switched back to the original front and noted that the case got a bit louder and warmer compared to before when I used the Booster. There was significant heat buildup on the front cap, especially around the area where the Booster Cell fan would be located — so it was time to take a deeper look.
AMBIENT TEMP: 28°C (hot in Sweden atm)
HARDWARE
  • GPU: RTX 3080 XC3
    • Undervolt: 837mV, 1875Mhz
  • CPU: 5900X
  • PSU: SF600
  • Motherboard: Strix X570-I
  • RAM: HyperX Fury 3200Mhz 64GB
  • AIO: Corsair H55 + NF-A12x25
    • Fan set to pull/intake
  • Motherboard fan: NF-A12x15
    • Fan set to push/exhaust
  • Booster Cell (later) + Silverstone 120x15mm fan
FAN SPEEDS
We targeted GPU thermals of 75°C in the original configuration to see how they would improve with the Booster Cell. Noise levels were ~44dB 30cm from the case.
  • GPU fans (3): 1650 rpm
  • Motherboard fan: 1500 rpm
  • Booster Cell fan: 1500 rpm
RESULTS — 3080 XC3 (CUDA rendering)
  • Original front cap: 77°C
  • Booster Cell: 70°C
ADDITIONAL NOTES
  • The case didn’t heat up as much overall (not only cooler on the front cap)
  • Further 2°C GPU improvement can be achieved by setting the AIO fan to push/exhaust, but it worsens CPU thermals. Pull/intake yields more balanced results across the GPU/CPU.
We will redo everything officially using standard benchmarks though, but now there’s a clear point to it.
Edit: haha @For_Science talk about a good coincidence, even if there’s no such thing, only the illusion of coincidence ;)
For_Science
447
613
Sweden
HARDWARE
  • GPU: RTX 3080 XC3
  • CPU: 5900X
  • PSU: SF600
FAN SPEEDS
ADDITIONAL NOTES
Whether you do this for the marketing material is up to you, but for the testing it would be desirable to allow the fans for the non-booster cell configuration to go higher to match the noise of the system with the booster cell. This is important to demonstrate the specific improvement of the booster cell than rather just having more generic airflow. I.e. if the same effect can be achieved by for example increasing the GPU fanspeed, then it is less attractive. I assume adding the booster cell has its own noise penalty, and so the configuration without it needs to be allowed to increase its fans to match the noise of having another fan.
AlexTzone
Sep 23, 2017
1,355
2,841
Sweden
thor-zone.com
Sure can do that, what would be a good noise level to target for them both?
Allhopeforhumanity
548
539
Denver
Probably depends on your measuring technique (how far from the system) and the noise-floor of the test bench. At ~20" maybe something like 35dBA would be a good metric (usually corresponds to around 1200-1500 RPM on a GPU). What's going to be most important is the relative performance for some reasonable distance, so pick a metric that sounds decent to your ear and just make that the standard, since its going to be a bit different for any end user anyway.
For_Science
447
613
Sweden
yeah...its always a bit of an open discussion when it comes to noise normalization (e.g. do you increase the GPU fan speed? AIO fan speed? etc). I would say set the booster to a fixed rpm of whatever, and then increase the GPU fan speed of the non-booster cell to match the noise of the booster-celled unit. But dunno, ultimately its up to you and somebody will find a way to be unhappy with the setup so don't dwell on it for too long ;)
AlexTzone
Sep 23, 2017
1,355
2,841
Sweden
thor-zone.com
Alright here we go, 4 tests later and more clean data! The rig is configured exactly the same as in the previous post I made.
Case configuration: MJOLNIR w. Performance Panels and 2 Top panels (no O2 panel, so slightly worse for thermals)
Benchmark: Heaven 4.0 (DX11, Ultra, Extreme, -, -, x8, 2160p) - 10min
Test #1 - Target 50dB from 30cm
  • GPU fans: 2150 rpm
Results
  • Stock front: 81°C
  • Booster Cell: 75°C (-6°C)
Test #2 - Full speed (Booster Cell / Motherboard fan)
  • Motherboard fan: 2250 rpm
  • Booster Cell fan: 2250 rpm
Results
  • Stock front: 76°C | Noise: 51dB from 30cm
  • Booster Cell: 71°C (-5°C) | Noise: 53dB from 30cm
The type of fan you use with the Booster Cell will of course make a difference, especially in sound. Unfortunately I don't have a second NF-A12x15 and had to use a slim Silverstone fan. In the first test the GPU noise overpowered the Booster Cell & Motherboard fan - that's the reason the dB doesn't change.
beerbuddha
222
213
I have probably miss connected something and probably need some insight from the crew here.
Corsair H60
AMD 5600X
ASUS B550-i
Mobo Flashed to latest FW - got access to PBO2 - undervolted to curve 30.
Thermal "idle"
CPU46C
Motherboard40C
CPU Package51C
Chipset72C
FAN:
CPU FAN0671 rpm
Chassis Fan 10 (I don't know why...it is connected and spinning...probably a 3pin vs 4 pin splitter)
AIO Pump4054 rpm
VRM HS Fan0 rpm
According to ASUS mobo manual: my AIO 3pin go to AIO Pump connector and my radiator fan goes to CPU Fan (with a splitter), My Chasis Fan has a splitter connecting with the noctua A12x15mm (using splitter when I'm going to eventually connect the booster cell)
HOWEVER friend with same config as me (all parts same except PSU) - corsair manual states:
- put 3 pin to CPU fan
- put radiator to chassis fan
- ignore AIO Pump.
These numbers are without the Mjolnir box inserted (currently open case - waiting for custom cables)
When playing a game I'm going to 50-55degrees. During "boot" we are at 62degree. Some weirdo instance, my comp would reboot randomly.
Are these numbers normal? are my connectors good according to y'all?
Is something off and I should be checking?
AIO Block is bolted
Should I connect the booster cell to add exhaust which would help? (don't think so because currently its open case so heat is just going all over the place)
JCB42
Does anybody know if the air cooler NH-L12S will fit in the Mjolnir? based off Noctua's page it's seems the lowest profile that can handle a R9 5000x with ease.
Leaving the radiator space to cool a top end GPU.
uber_shnitz
72
88
It won't fit. The Mjolnir has 51mm height for air cooling and the L12S is 70mm tall. I don't remember who but someone here was going to try a C7 which would fit on a 5000X CPU IIRC.
keepcoding
121
134
blog.keepcoding.ch
Corsair H60
AMD 5600X
ASUS B550-i
Thermal "idle"
CPU46C
Motherboard40C
CPU Package51C
Chipset72C
FAN:
CPU FAN0671 rpm
AIO Pump4054 rpm
VRM HS Fan0 rpm
- ignore AIO Pump.
AIO Block is bolted
I dont see anything off with your numbers, the random reboots are probably just caused by the undervolting
JCB42
Cheers thanks. I just hope a cryorig or the mysterious ali express AXP90-X53 can handle a R9 5000X. And this is an ambitious bit, without an undervolt? Can it be done?
supey
Just curious and hoping someone knows (or hopefully Alex can chime in) but if I were to get in on the next pre-order, what's the timeline looking like before receiving the case?
