Woahhh steel in the wild!! Nice ltt desk pad btwHOLY KING KONG IN A THONG IT TOOK TOO LONG!! THOR'S HAMMER FINALLY ARRIVED!!!! Will be posting soon with a complete build.
Superb write up! If you're not camera shy would love to see video comparisons between the cases (start a Youtube Channel?Well here is the Thorzone build all finished.
Thanks for the super thorough review I really appreciate it!
Well here is the Thorzone build all finished. Overall it was the most fun PC Case to build in. I loved how it drops into the chassis like a sheath. It was also very handy that everything was tied up inside. I did find a couple of issues and possible critiques. One of the rails from the inner core didn't have a screw so it was flopping around. The second was the magnets that hold the panels on have this really weird black residue.
A critique would be that the IO shield hole in the case needs to be wider. I had to take a grinder after removing the IO shield and grind the IO sheild down until it would fit. Another possible improvement is the holding area where the motherboard sits may need to have slightly higher stand-offs. My reasoning is the plate that keeps pressure on the heatsink on the Cryorig C7G comes into contact with the edges of the cutouts inside the motherboard "tray" (if you could call it that.) As a result, the motherboard bends quite a bit and I had to loosen the screws to ease tension. If I had to summarize it, there is too much height in the middle of the motherboard created by the back plate, and the height on the corners is too low causing a bend.
If I had to compare it to the Ghost S1, the Mjolnir is WAAYYY better. In a different league. The metal is outstanding and the panel thickness is hotter than all thighs. It would definitely qualify for death by snu snu. And the SOUND! Somebody make an ASMR video of the ..... rubbing.
When I was building the XTIA I forgot to take better pictures but you can see some on my Instagram @delduked Alex might recognize the Instagram tag from me commenting too many times on his thorzone Instagram page
Comparing it to the XTIA Proto, the XTIA may have a slight leg up on it because it's a different kind of case. I don't think you can really compare the two because one is an open-air case and the other is not. However, the XTIA did have very nice materials but building with it was a little more complex and not as enjoyable. I think the Mjolnir was far easier, better thought out, and more fun.
Now comparing it to the Formd T1, it was probably the lowest quality out of the four. It does have an advantage for component accommodations but it was more frustrating in comparison. You could tell the Mjolnir was very well thought out despite those two main critiques I had talked about. The panels on the Formd T1 are nowhere near the quality of the Mjolnir, the thickness and quality of the construction is really amazing. In my Formd T1 I built a full quick disconnect water loop and also air-cooled it with a blackridge and it was just annoying finishing the case with those awful panels. The Ghost S1 in terms of ease of use is almost identical to the Mjolnir but the Ghost S1 quality falls short. The XTIA was fun and a cool design but not very good for long-term use. After building in all 4 (including an NZXT H1) I've never encountered such a well-built case as the Thorzone Mjolnir.
SPECS include:
MOBO: msi meg x590i
CPU: Intel Core i9 10900F
GPU: RTX3070 FE
SSD: 970 EVO 1tb
RAM: 32gb HyperX 3200mhz
CPU COOLER: Cryorig C7G
with black pslate cables for the Ghost S1
SPECS include:
MOBO: msi meg x590i
GPU: RTX3070 FE
SSD: 970 EVO 1tb
To the other two human who happen to have a 6800XT Reference and is wondering if it would fit inside the Mjolnir, rejoice!
It fits, I think this might be the maximum thickness this case can handle though, it was pretty nerve-wrecking sliding the core back into the shell. (card thickness is 2.5 slots according to spec)
I couldn't find anybody else with the answer to this question so I decided to find out myself.
Sorry in advance for the barrage of questions, but I figured maybe you can help out with some I had:
How are the thermals looking with that setup?
How was building with the Ghost S1 cables? Would you say they're overall adequate? I think someone else mentioned building with NCase M1 cables too.
Were you using the flipped PSU configuration when building so cable plugs facing upwards on the PSU (asking also in relation to the above custom cables)?
| 4801.15 MHz (Core #0) | 35 degC (95 degF) (Core #0) |
| 4701.13 MHz (Core #1) | 36 degC (96 degF) (Core #1) |
| 4701.13 MHz (Core #2) | 35 degC (95 degF) (Core #2) |
| 4801.15 MHz (Core #3) | 35 degC (95 degF) (Core #3) |
| 4701.13 MHz (Core #4) | 40 degC (104 degF) (Core #4) |
| 4601.10 MHz (Core #5) | 36 degC (96 degF) (Core #5) |
| 4701.13 MHz (Core #6) | 35 degC (95 degF) (Core #6) |
| 4801.15 MHz (Core #7) | 35 degC (95 degF) (Core #7) |
| 4801.15 MHz (Core #8) | 35 degC (95 degF) (Core #8) |
| 4801.15 MHz (Core #9) | 35 degC (95 degF) (Core #9) |
Hi, Alex! Great news. I'm going out on a limb with this post, but I've already contacted the moderators and haven't heard back from them yet. As I mentioned here I have been trying to start a cable business for over a year and I think this is the perfect opportunity.Just ordered stuff for making customs cables, this will be my first attempt but I will measure every single cable (in case it turns out good) so hopefully you guys will have a better foundation![]()
awww man wish you offerred this 3 weeks ago - i actually ordered custom cables off Etsy (they from china)Hi, Alex! Great news. I'm going out on a limb with this post, but I've already contacted the moderators and haven't heard back from them yet. As I mentioned here I have been trying to start a cable business for over a year and I think this is the perfect opportunity.
I was thinking of setting up a page on Etsy and charge between 25-35 USD for unsleeved cables and between 45-55 USD for PET Sleeved cables (For those of you who might want to use the tempered glass panel). I tried to verify myself and sell on Reddit but I can't afford a website and it is a requirement requested by the moderators over there. At the moment due to covid shipping prices have increased and shipping to USA is around 20 USD. (I can call and quote other countries).
I don't want to spam anymore and I apologize if this message bothers any of you. If you have doubts or are interested you can contact me privately or here. Thanks for your attention![]()
Hi, man! Thank you so much for your encouraging words. It really means more than you can imagine. As I said, I'm trying not to break any rules until I'm cleared by the moderators, that's why I've been quiet.awww man wish you offerred this 3 weeks ago - i actually ordered custom cables off Etsy (they from china)
If you doing it, wish you luck and success on this. After dealing with "stock" cables, custom cables is a must and considering all the custom cables places out there offering over 4 weeks for orders, im pretty sure there is room for another player in the spectrum
Totally understand - again best of luck and obviously having someone active here that can do it similar to how Alex been actively here gives good insight of the potentialHi, man! Thank you so much for your encouraging words. It really means more than you can imagine. As I said, I'm trying not to break any rules until I'm cleared by the moderators, that's why I've been quiet.
It has been especially difficult to start this project because the big fish offer things like measurements already taken for the most popular cases and I can't afford them at the moment, but your words encouraged me a lot and I want you to know that. If all goes well, maybe in the future when you start another SFF adventure I'll be here![]()
Any update from UPS on Europe shipping?
Nah, they won't even answer...let me guess, they are working as fast as they can and "hope to get an answer from UPS next week" ... (same same)
I don't think I will get my case before some time in August.
And it’s been like a month that some non backers have received their case…
Covid is not something that happened yesterday, it is no longer an excuse. You know you’ll face these problems, you don’t wait the moment the cases are ready to start looking for shipping options.I think that really just comes down to the complications in shipping due to covid, and flipping to air transit requiring a renegotiation in freight handling in many parts of the world, the EU in particular. I mean, it super sucks for people who haven't received their case yet, but it also doesn't make sense to sit on completed/packaged chassis if they can send them out to post-backer-orders while they continue working on the shipping issues, both from a "cost of storage" and a "customer service" perspective. Basically, it's not a zero sum game, non-backers getting theirs is not the bottleneck in EU backers receiving theirs.
