Stalled Mini reservoir + fill port for SFF Cases
Nouvolo
Creator
760
1,713
www.nouvolo.com
Great work by @Goatee, tho for this product to come to light, I am opting for a design that is symmetrical. This would solve orientation problem. Otherwise, with the trend of motherboards, compatibility would be a major issue. Not going to make a product that fits only couple motherboards.
Another approach is to make a thicker version of "Aquanaut" with reservoir built in. And it will most likely not fit with T1 in triple slot config. But hey, if we go down this path, if it fits T1 then great, if not then T1 needs to go wider. ?
  • Haha
Reactions: thelaughingman
oOflyeyesOo
120
55
Make both options! Cover all bases of sff possibilities.
